Thread: What product to clean EGR
    West Yorkshire
    Default What product to clean EGR
    Planning on cleaning EGR this week following a dose of 10kboost and subsequent sluggish response.
    What product should I be using to clean the EGR? Carb Cleaner and a tooth brush??
    Regular Member sloper's Avatar
    Oct 2010
    bradford
    loadsa WD40
    Feb 2007
    North west
    carb cleaner is far better. about £4 to £5 from a motor factor
    Vehicle : Signum 2.0 DTi
    Trim : Elegance/Elite
    Engine : 2.0DTi
    Mileage : 73350
    Carb cleaner , not to sure wd40 would be a good idea on electric,s
    and still loving it
    West Yorkshire
    Cheers guys - got a tin of Carb Cleaner from when I cleaned the Boost Sensor at weekend.
    Was really filthy - since cleaning and running 10kboost the car has been really laggy and sluggish...
    Hope it's just muck that's been dislodged from the EGR making it's way through - should have stripped it down before the 10k boost on reflection
    lowestoft
    Hi there what car u gof if u got a 1.9 150 it is not the soot that messes up the egr valve it is the damp and mostiure that gets in the solinode. I cleaned mine up other day car has all its power back. If u need to no more about cleaning just ask hope u get sorted
    preston
    carb cleaner + toothbrush for valve
    follow how 2 and split solenoid - then use wd40 or lithium grease spray for the solenoid.
    West Yorkshire
    Quote Originally Posted by mparks8590 View Post
    Not fancying splitting the unit, seen the pics - would rather give it a clean with what's accesable, if that doesn't sort it I'll replace it....
    lowestoft
    I ws worried avout taking it to bits but all ok done it last night took half hour. Up to u. Take black pieace off side of case and see if u can move little pin in tbe middle mine was solid. Should move freely
    Nov 2010
    *!dave!* - The Black Country
    After cleaning and before fitting it to engine put 12v across the 2 terminals
    The solenoid (EGR valve) should click and you can see the valve open and close
    If it doesnt and you are happy all is clean and not seized then replace the EGR as it is goosed
  1. Product key code
    By Blurry120 in forum General Chat
    Last Post: 13th November 2012, 23:49
  2. DA and product
    By Derek Mc in forum Detailing and Car Care Discussion
    Last Post: 3rd May 2010, 18:29
  3. The finished product!!!
    By george1987 in forum Vectra C / Signum Car Chat
    Last Post: 30th April 2010, 12:55
  4. mequiars new product,s
    By bobssignum in forum Detailing and Car Care Discussion
    Last Post: 19th March 2009, 00:10
  5. New product
    By blr123 in forum Detailing and Car Care Discussion
    Last Post: 11th June 2006, 13:56
