Thread: removing brake hoses
    preston
    Default removing brake hoses
    hi
    when removing brake hoses, do you unscrew the union nut on the brake line first? then remove hose
    or do you take retaining clip off first?
    and how does retaining clip come off?
    anyone done this when going to upgraded brake hoses?
    thanks in advance
    Regular Member keith150882's Avatar
    Oct 2009
    boston
    Vehicle : Cdti 150
    Trim : Sri
    Hi iv just put hel brake lines on u can't get clip of until u have undone nut and u need it so leave it ! Don't think it matters witch one u do first just make sure all bits are handy as it will empty y reservoir I just keeped it top u after each one !
    preston
    thanks
    mine are hel
    mine came with fixed fittings on the front and on the rear it came with a nut fitting...
    how odd but thats how they came
    how easy was it free the union nut?
    Regular Member Diesel Dude's Avatar
    Norfolk
    Just a quick tip to stop the brake reservoir emtying itself, fill the reservoir as full as you can get it then stretch a pastic bag tight over the top and hold it on with a tight elastic band this will stop any air getting in and stop the flow of fluid out of the open brake pipe end, you will loose a little fluid but not as much as leaving the top open.
    scotland
    Quote Originally Posted by Diesel Dude View Post
    DUREX lol
    preston
    good tip.
    how much fluid do you need to bleed everything and replace the exisiting stuff?
    Norfolk
    I used 2 litre when i did mine, but i did change the clutch fluid aswell.
    Oct 2009
    boston
    Vehicle : Cdti 150
    Trim : Sri
    Quote Originally Posted by mparks8590 View Post
    thanks
    mine are hel
    The one they sent me two nuts was 10 mm thread and two are 12 mm this is wrong thay both need to be 12 mm so just check! Thay are sending me two more for back !
    preston
    do you mean the banjo bolts? or the bit that joins to union nut?
  1. For Sale: HEL braided brake hoses
    By Big Red in forum Parts for sale
    Last Post: 16th April 2012, 20:08
  2. Brake Hoses
    By lizard in forum Handling & Braking
    Last Post: 8th August 2009, 21:14
  3. Brake hoses cut on VXR Calipers
    By WooSAABy in forum Vectra C / Signum Car Chat
    Last Post: 7th January 2009, 00:09
  4. Braided Brake Hoses
    By parsco in forum Handling & Braking
    Last Post: 12th December 2008, 17:36
  5. Brake hoses ?
    By FIL 4822 in forum Vectra C / Signum Car Chat
    Last Post: 18th September 2008, 15:13
vectra c brake hose removel
