Results 1 to 10 of 11
Thread: Strange This!
    Regular Member Si-SRI's Avatar
    Oct 2009
    LINCOLNSHIRE
    rolleyes Strange This!
    Parked the car in the drive this afternoon...turned off,took the key out and a clicking noise started behined the dash...sounded behind the speedo area...rearly fast..constant for roughly 10seconds then stopped...
    Any ideas?
    everythings working as it should...if somethings going to go it better hurry up its out of manufacturers warrenty end of march,
    Car as per my sig if required.
    Admin plasma's Avatar
    On the Forum
    265 Post(s)
    Engine : 150
    Mileage : 74000
    Sounds like you hit an indicator and enabled parking lights?
    Plasma's Tech2 services are now partially open and able to provide services
    Come Join our new forum Insignia Owners.com for all your Insignia chat and needs
    Regular Member Jezzy's Avatar
    S.E
    That would be a beep though surely, not a clicking?
    Oct 2009
    LINCOLNSHIRE
    When you put parking lights on it beeps then the indicator stays on the dash for a while..definatly not that...sounded like a relay if anything...
    S.E
    Could be the air recirculation flap getting stuck
    Sep 2009
    Glasgow
    i had this same noise and a day later my resistor pack for heating went and fans would only work on 4 th setting.
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Mine does this, although very quiet. Can't hear it unless you practically put your ear to the steering wheel! It's never bothered me though. Would be nice to iknow what it is though...
    2003 2.2DTi SRi Vectra
    Oct 2009
    LINCOLNSHIRE
    Quote Originally Posted by nokiaman1978 View Post
    Off on a 150 mile trip in the morning so if it's gonna go it'll be when i'm miles away from home you watch....probably in the right area though and noticed the fan on no-1 does appear a little noisy don't know if thats anything todo with it,scuttle panel all clear recently changed pollen filter....
    Jul 2009
    The Rift, Cardiff
    Its probably a broken cog tooth on the re-circulation flap. When you turn off or lock the car the flap closes. Easy to check by removing the glove box and seeing if the flap on top of the heater blower (bellow the pollen filter) opens and closes when you press the re-circ button on the heater controls.
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Press the recirculation button, if it makes the niose when you press it again then I would say the motor which controls the reciculation flaps has broken some teeth on its gears. Noise actually comes from behind the glovebox compartment.
    Gazza4
  1. Strange, Strange and Gardener
    By robintwall in forum Vectra C / Signum Car Chat
    Last Post: 25th January 2009, 18:02
  2. Somebody said something strange...
    By Danwells72 in forum Vectra C / Signum Car Chat
    Last Post: 21st May 2008, 21:39
  3. Strange
    By FRANKA in forum Vectra C / Signum Car Chat
    Last Post: 14th December 2007, 00:17
  4. Strange One - Bit of Help
    By breezephil in forum Vectra C / Signum Car Chat
    Last Post: 1st May 2007, 23:37
