Thread: EGR valve
    Glasgow
    Default EGR valve
    What does EGR stand for & what's it's purpose?
    Also having had a read through the forums I noticed a 1.8 vec owner blanked the EGR off, why would you do this?
    G
    Jul 2009
    The Rift, Cardiff
    Exhaust Gas Return/Recirculation value. It puts exhaust gas back into the combustion process to reduce harmfull emissions.
    Blanking it off reduces soot (not really an issue on 1.8's) and I think it can increase power. Also one less thing to go wrong. A tech2 session is required to program it out if blanking.
    Glasgow
    Quote Originally Posted by ChrisBilly View Post
    Is it worth while doing?
    G
    Jul 2009
    The Rift, Cardiff
    If its not giving you problems I wouldn't bother. My egr was leaking/sucking air and causing the eml to stay on, and making the the car run rich. I tried blanking it but it choked the engine and kept cutting out unless I held the revs really high. In the end I got a genuine second hand egr for £20 (cheaper than a tech2 session) and the problem was solved.
    I think i've read of people not needing tech2 but might be confusing it with the 2.0.
  1. Brake servo Valve (one way valve)
  2. Replies: 6
    Last Post: 29th July 2012, 13:52
  3. Egr valve, swirl valve problems etc..
  4. EGR valve / Swirl valve
    By SwavGav85 in forum Engine & Drivetrain
    Last Post: 5th January 2009, 17:17
  5. EGR valve and Swirl Valve
    By TUX-VECTRA in forum Vectra C / Signum Troubleshooting
    Last Post: 6th July 2007, 00:43
