Results 1 to 10 of 11
Thread: Routing of amp cabling etc
    Regular Member mickydoos's Avatar
    Aug 2009
    Crawley, West Sussex
    Default Routing of amp cabling etc
    Hi guys,
    I've got myself an amp and sub ready to go into my Vectra. However after much searching and coming up with nowt, I have to ask: Where should I route my power leads / RCAs??
    A little info on what I want:
    My sub and amp are to go on the right hand side of the boot. Temporarily the amp will be screwed to the back of the seat until I have time and decent weather to make up a panel on the right side.
    I've heard its best to run power cables and RCA's separately but all opinions are what not are welcome!
    Liverpool
    Run your cables down the passenger side of car
    There is an unused gromit behind glovebox next to pollen filter which you can use to get access from the cabin into engine bay
    morecambe
    44 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    Yup, down the passenger side. Never had an issue with running RCA's and power cable together before.
    Regular Member alzsxi's Avatar
    Maidstone, Kent
    Run the power cable down the passenger side and the RCAs down the driver's side, you don't always get interference if you run them together but why take the chance?
    Full Member paul.sessions's Avatar
    leighton buzzard
    Quote Originally Posted by alzsxi View Post
    this is what i have done there is a grommet behind the glovebox you can run cables through.
    Ely, Cambridgeshire
    61 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    Picture below, take the glove box out and this is the grommet everyone's referring to that's behind it, pic shows mine after routing a 4 gauge cable through the side of it.
    Northern Ireland
    I ran my power cable down Passenger side but wasn't sure where to runnin rca's but after readinghis thinkk I'll run them down drivers side. I took my earth from the bolt under the back seat on the right hand side.
    Maidstone, Kent
    The grommet I used:
    Nottm
    It's not always that you'll get interference but is possible I ha an issue when running 0gauge wiring through my corsa never took the chance after that it's something to do with the positive current that creates a magnetic field and interferes with the current in the phono leads, shopud be ok with newer cars though as they tend to be better earthed.
  1. Routing wires
    By JonnyB_UK in forum Electrical & ICE (including SatNav)
    Last Post: 12th April 2012, 21:42
  2. routing
    By Big Knox in forum The 'Off Topic' room
    Last Post: 13th January 2010, 08:50
  3. Cable Routing
    By Damian in forum Electrical & ICE (including SatNav)
    Last Post: 29th November 2005, 18:07
