Results 1 to 10 of 13
Thread: DMF, Clutch and bushes changed
    Engine : 1.9 CDTi
    Default DMF, Clutch and bushes changed
    Changed my clutch, flywheel, gearbox oil and anti roll bar bushes today.
    It drives so much smoother.
    No more rattling and notchyness when the engine is cold (Although I never knew there was a problem till I drove it after the work was done)
    Noticed both my inner rack joints had slight play so going to change them and thats all the jobs done that I need to do
    Regular Member bangty 1's Avatar
    Sep 2010
    in a box
    nice job mate ent the clutch a pain?? did it spin itself solid?? but nice job cracked on today mate
    Engine : 1.9 CDTi
    It was still moving ok (well too much lol)
    The play was in and out which is why it was still moving ok but rattling.
    Sep 2010
    in a box
    mine lock had to cut it to get to bolts not nice at all
    Rochford
    How long did it take you? I am attempting mine this Friday with a mate. Allowing all day, is it possible in a day? We are both reasonably ok with spanners.
    Sep 2010
    in a box
    day easy mate
    Engine : 1.9 CDTi
    Yeah took about 7 hours in total but that was for everything (Inc a inner rack joint)
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    Default dmf!
    Hi, I found one of your old posts regarding changing the dmf, I have a vec cdti 150 & i get some rattling & off balance type chugging on tick-over (more when cold), There maybe something else but the dmf throwing an in balance isnt helping things, Is it really do-able on the floor or better over a pit, I understand half or all of the sub frame has to be dropped? only undoing half will preserve the front end alignment i presume but dropping it completely would be a different matter, If you could give some pointers i would be great-full, cheers .
    Engine : 1.9 CDTi
    Not tried it over a pit but wouldn't attempt it on the floor.
    Its a heavy box and really needs 2 people to manoeuvre it out.
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    Quote Originally Posted by lee gsi View Post
    did you put it on axlle stands then i presume.
  1. Clutch and DMF changed, now awfull noise!
    By redmans in forum Engine & Drivetrain
    Last Post: 15th July 2012, 18:21
  2. CIM CHANGED NEED TECH2 in OXFORD AREA HAS ANYONE CHANGED A CIM BEFORE?
    By vectrasimonsri in forum Electrical & ICE (including SatNav)
    Last Post: 10th July 2011, 20:43
  3. Changed clutch and flywheel yesterday
    By stupot555 in forum Engine & Drivetrain
    Last Post: 7th July 2011, 22:28
  4. Anyone changed their front ARB bushes?
    By Telly Addict in forum Suspension, Wheels & Brakes
    Last Post: 19th March 2011, 08:40
  5. Anyone changed their own Clutch & DMF?
    By lee gsi in forum Engine & Drivetrain
    Last Post: 12th January 2011, 21:05
