Results 1 to 3 of 3
Thread: will the pedal test show up abs faults?
    Regular Member TimTay's Avatar
    Nov 2010
    BRECHIN
    Default will the pedal test show up abs faults?
    hi all, still havin issues with my abs and tc not working and no lights. but got a pm from a fellow member saying he just took his clocks out as he was having the same problem. low and behold he had black tape over both the lights. so i said to my self mine maybe......na.... went and took them out for a look and yep you guessed it both lights taped up! at that point i nearly launched the clocks across my living room. so as above will the pedal test check abs as well as engine. cheers!
    Jul 2009
    The Rift, Cardiff
    I've tried but it didn't show abs codes for me, abs light was on.
    Nov 2010
    BRECHIN
    cheers for that.
  1. pedal test
    By GCusdin in forum Troubleshooting
    Last Post: 1st February 2013, 12:07
  2. Pedal test won't work
    By johp778 in forum Electrical & ICE (including SatNav)
    Last Post: 2nd January 2013, 17:09
  3. done pedal test and
    By DAVIDD88 in forum Engine & Drivetrain
    Last Post: 26th March 2012, 22:07
  4. Live Data from test - no faults stored
    By ScottyV6 in forum Troubleshooting
    Last Post: 2nd June 2011, 20:28
  5. Pedal test
    By yadziyad in forum Electrical & ICE (including SatNav)
    Last Post: 16th October 2009, 20:02
