Thread: AF33 external oil cooler?
    Regular Member delboy2028's Avatar
    Jan 2010
    grimsby
    Vehicle : vauxhall
    Trim : 150
    Engine : 1.9 cdti
    Year : 54
    Default AF33 external oil cooler?
    Any one on here changed the oil cooler on the vectra auto box to an external after market oil cooler.
    wanting to do this on mine as a preventative but wont to buy the correct size radiator and know the best placment and pipes for my vec c
    cheers in advance
    i mean is this too big
    http://cgi.ebay.co.uk/UNIVERSAL-30-R...item2c598febe9
    Regular Member benny's Avatar
    Feb 2006
    dudley
    the vec c v6 cdti auto box wich is a uprated af33 ish had a external oil cooler fitted that went infront of the rads ....ill try and find the part numbers ,
    Jan 2010
    grimsby
    Vehicle : vauxhall
    Trim : 150
    Engine : 1.9 cdti
    Year : 54
    Quote Originally Posted by benny View Post
    that would be great cheers
    Regular Member Jezzy's Avatar
    S.E
    Is this to stop the gearbox oil mixing with the coolant?
    Jan 2010
    grimsby
    Vehicle : vauxhall
    Trim : 150
    Engine : 1.9 cdti
    Year : 54
    yer to prevent before owt does happen
  1. AF33 fluid change
    By csd_19 in forum Engine & Drivetrain
    Last Post: 16th November 2011, 23:07
  2. af33 box again bit of info needed
    By davis6161 in forum Engine & Drivetrain
    Last Post: 11th June 2011, 10:04
  3. af33 into 2.2 elite
    By cerbrious in forum Engine & Drivetrain
    Last Post: 2nd September 2009, 19:29
  4. How do i Know if i have AF23 0R AF33?
    By mikaj in forum Engine & Drivetrain
    Last Post: 2nd August 2009, 14:11
