View Poll Results: Replace the egr valve with
Voters
2. You may not vote on this poll
  • The fiat 'blanking' gasket
    2 100.00%
  • just replace with new normal gaskets
    0 0%
Results 1 to 2 of 2
Thread: Did an engine clean
    Regular Member aerodynamic18's Avatar
    Aug 2007
    Lisburn, N.Ireland
    Default Did an engine clean
    yest i cleaned the boost sensor and then used the 10k engine cleaner and i think i have noticed a difference. it deff picks up better and high speeds come up a lot faster than i can remember for a bit so im well happy deff was worth it now im thinking about checking the egr valve out next weekend. if i was what do ppl think i should do? have a look and put back on with new gaskets or refit with the fiat gasket. also can anyone give me the part numbers for the gaskets i need? its a 1.9cdti 150bhp thanks
    Regular Member farley2708's Avatar
    antrim n.ireland
    Default engine clean
    on the blank oval gasket,you can either keep it solid or drill a 6-8mm hole in the middle,think if you keep it blank you need to do a re-map to take away the EGR
  1. Engine Clean - Before & After
    By Aidi in forum Detailing and Car Care Discussion
    Last Post: 3rd April 2011, 20:10
  2. first clean since new engine.
    By whiskyno7 in forum East (RO - WhiskyNo7, ARO - Plasma)
    Last Post: 19th March 2011, 21:09
  3. how do you clean an engine?
    By monty2000 in forum General Chat
    Last Post: 15th June 2010, 10:20
  4. Engine bay clean
    By Graham in forum Vectra C / Signum Car Chat
    Last Post: 26th August 2009, 09:52
  5. engine clean.
    By jun in forum Detailing and Car Care Discussion
    Last Post: 17th February 2009, 11:03
