Thread: diesel leak - any advice
    Regular Member mooney's Avatar
    North west
    Trim : VXR
    Engine : 2.8 v6 turbo
    Year : 06
    Default diesel leak - any advice
    I've got a 2.2dti signum,
    pulled up yesterday and got a slight smell of diesel
    so opened the bonnet took off the plastic cover and had a look,
    found roughly where it was coming from, started it up and it must be a tiny hole making a very fine mist, its one on of the metal pipes though
    anyone know how to replace the pipe, cant really see where it starts, anyone got any ideas?
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    It starts at the fuel pump. Never thoughts these could "split"
    Administrator plasma's Avatar
    On the Forum
    405 Post(s)
    Engine : 150
    Mileage : 74000
    Probably more due to corrosion than splitting
    North west
    Trim : VXR
    Year : 06
    anyone got any idea how hard its going to be to change?
    dudley
    Quote Originally Posted by mooney View Post
    easy job, remove the inlet and egr valve first to gain some access, space is still quite tight, so you'll need a stubby spanner as well as a normal 17mm. they only come in sets of two, so if it can't be soldered, then its down to vauxhall, I managed to solder mine with some silver solider,
    they are under a little tension, so when you refitt do the pump end first,
    Jul 2009
    barnsley,yorkshire,GB
    Engine : 20 Dti
    as olid says pretty easy just a bit fiddley,remove support clamp take off injector end then pump connector,fit pump end finger tight untill you get injector coupled then tighten both ends,don't forget to refit clamp or vibration will fracture pipe.
    North west
    Trim : VXR
    Year : 06
    cheers guys
  1. Slight diesel leak from Diesel filter housing :-(
    By rollercoaster63 in forum Engine & Drivetrain
    Last Post: 22nd July 2015, 21:18
  2. diesel leak
    Last Post: 6th January 2013, 22:53
  3. diesel leak
    By chris1804 in forum Vectra C / Signum Troubleshooting
    Last Post: 26th November 2011, 20:57
  4. diesel leak - any advice
    By mooney in forum Vectra C / Signum Car Chat
    Last Post: 13th February 2011, 02:29
  5. diesel leak ??
    By danceade in forum Vectra C / Signum Troubleshooting
    Last Post: 12th February 2008, 02:09
