Thread: Tie Rod Ends
    Apr 2006
    Kingswinford
    Trim : LS
    Engine : 2.0 DTI
    Mileage : 150000
    Default Tie Rod Ends
    Can anyone recommend a ball joint separator for the track rod end. Don't fancy bashing the hub or using a fork tool.
    Its for a 2.0 DTI, 53 plate.
    Thanks in advance:
    Apr 2006
    Kingswinford
    Trim : LS
    Engine : 2.0 DTI
    Mileage : 150000
    Anyone ????
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Northampton
    Engine : A20DTH
    Mileage : 88000
    I have this one but the other one is better
    http://cgi.ebay.co.uk/SYKES-PICKAVAN...item588c7bf363
    Apr 2006
    Kingswinford
    Trim : LS
    Engine : 2.0 DTI
    Mileage : 150000
    Merikiito, thanks for your response. But the first link is a SYKES PICKAVANT FACOM BALL JOINT WIPER ARM TOOL 660310 ( http://cgi.ebay.co.uk/DRAPER-EXPERT-...item439a5fcd10 ), is that adequate for the tie rod ends ????
    Regular Member Jezzy's Avatar
    S.E
    You won't need one - I bought one from Halfords, which turned out to be too small when I came to do the job, so in the end I used the Edd China method - tap the side of the TRE with a hammer and it breaks the tension.
    Apr 2006
    Kingswinford
    Trim : LS
    Engine : 2.0 DTI
    Mileage : 150000
    Thanks Jezzy, I'll try the Edd China method.
    Regular Member vxpenfold's Avatar
    Nov 2010
    sittingbourne,kent
    2 Thread(s)
    Vehicle : Vectra Hatchback
    Trim : Life(well it was)
    Mileage : 166000
    ive got a ball joint splitter but in 3 years at vaux have only seen one be used once and that was only to apply pressure while twatting one cos iwas stuck fast lol, just give it a good belt on side of the hub where the track rod end its as jezzy says
  1. Replies: 5
    Last Post: 15th July 2010, 21:33
  2. Track Rod Ends Help
    By Padster72 in forum Suspension, Wheels & Brakes
    Last Post: 23rd April 2010, 14:13
  3. Track Rod Ends
    By Cat_J in forum Vectra C / Signum Car Chat
    Last Post: 16th February 2010, 01:14
  4. And so it ends!!
    By Maverick in forum Vectra C / Signum Car Chat
    Last Post: 11th November 2007, 19:29
edd china track rod ends
