Thread: poor radio reception with 8k HID's
    Feb 2011
    eastbourne
    Default poor radio reception with 8k HID's
    I recently fitted an 8k HID kit, looks great with vectra-c facelift headlights. Trouble is when headlights are switched on the radio receptoin is poor to the point I mostly listen to CD's.
    Any1 had this before or have any ideas how to fix?
    Slough
    92 Post(s)
    Vehicle : insignia vxr
    Trim : vxr
    Engine : 2.8 turbo
    Year : 61
    Mileage : 38000
    had this on mine but was 6k turned out to be a faulty ballast , try putting on just the side lights radio should be ok then when you put the headlights on then youll get the interference , send it back and get a replacement one when did you buy them .hid-direct give you a 2year warranty on the ballast . khalid
    the vectra has gone , but not far away so ill still see it form time to time
    Feb 2011
    eastbourne
    I got them from the carmodshop a few weeks ago. I have emailed them and they have told me this is not a common fault on vecta-c. One idea they had was to put foil around high voltage wires and ballast
    Slough
    92 Post(s)
    Trim : vxr
    Engine : 2.8 turbo
    Year : 61
    Mileage : 38000
    Quote Originally Posted by tights View Post
    dont know about putting the foil around anything . a few members on here had the same problem ,and this is what it turned out to be . have you tried what i said about just the side lights to see if the problem is there ,as this is what was happening to me as i was just using the side lights with the radio on but got the interference when i put on the headlights . i would still send them back and if they wont change them get your money back . khalid
    Administrator plasma's Avatar
    On the Forum
    410 Post(s)
    Engine : 150
    Mileage : 74000
    Khalid the technical guru on this subject now As said above its the ballast not being screen properly causing RF interference to the radio, putting 'tin foil' around something generating 25,000volts is NOT advised lol! Send the ballasts back and try another set or make.
    Feb 2011
    eastbourne
    Yep it is def only when dipped beam on. Think I will have it out with seller thanks
    Slough
    92 Post(s)
    Trim : vxr
    Engine : 2.8 turbo
    Year : 61
    Mileage : 38000
    Quote Originally Posted by plasma View Post
    i would not say that i even sorted out my phone hope you had a good day
    good to know as this is what was going on with mine and Dean (plasma ) told me that it was the ballast . khalid
    Feb 2011
    eastbourne
    I see that 1 of ur mods happypostie is a blue led dash conversion. Was this expensive to do and did u do it yourself?
  1. Poor fm radio reception (CD70)
    By av2009 in forum Electrical & ICE (including SatNav)
    Last Post: 5th February 2013, 18:51
  2. Poor Radio Reception Please Help
    By dizzy in forum Electrical & ICE (including SatNav)
    Last Post: 16th October 2008, 17:25
  3. poor radio reception ??
    Last Post: 16th October 2008, 16:34
  4. Poor Radio Reception
    By testbloke in forum Electrical & ICE (including SatNav)
    Last Post: 28th August 2008, 23:11
  5. Very Poor Radio Reception???
    By ChrisFox in forum Electrical & ICE (including SatNav)
    Last Post: 2nd January 2008, 20:36
