Thread: Drop links
    Regular Member themarbleman's Avatar
    sussex
    Default Drop links
    Yeah..........Easy enough to get to.....No Problem......Half a can of penetrating spray later and the B*****d still wont budge.Snapped the ratchet on the wrench,took some skin of the knuckles when i slipped,swore a bit,swore a bit more,told Jesus how i felt about the situation,sprayed on some more penetrating spray,huffed and puffed a little more... Had a nice little can of nelson and a muffin,Then gave up and washed the car .
    Now sprayed both sides and will leave it to work its magic for a week.
    Happy Days
    Jun 2009
    South Coast
    Vehicle : Vectra and a Signum
    Engine : Z18XE,Z19DTH,Z20NET
    its that the top and bottom nuts on both drop links that you are stuck with?
    sussex
    Yeah....Both sides stuck like S**t to a blanket......
    sussex
    Top and bottom..........
    Jun 2009
    South Coast
    give me a shout if you can't shift them next weekend... i think i used a breaker bar on the bottom nuts...
    sussex
    Doh...........Thanks fella
    Regular Member luke4487's Avatar
    Bordon, Hampshire
    Heya,
    Just wondering what your using to crack them off? If your using your ratchet it may be the problem as you need the solid knuckle bar
    A ratchet should never be used to crack off a torqued nut as it damages the mechanism and the freeplay inside it will take out some of the effort your putting in. Go out and but a 1/2 inch knuckle bar set if you dont already have one and use that. As said, get a hollow pipe or bar that can slide over the handle to give you more leverage
    They should be tight but not a mega problem...
    Full Member paul.sessions's Avatar
    leighton buzzard
    i used a breaker bar on the bottom nuts too still wouldn't budge then realised i was going the wrong way
    Bordon, Hampshire
    Haha thats brilliant! :P Lefty loosey, righty tighty
    Its okay I've seen trained mechanics struggle on a nut wondering why its so damn tight then realising they have made the worst mistake in the trade lol... always worth a few beer fines :P
  1. Drop links or not!
    By goafer in forum Suspension, Wheels & Brakes
    Last Post: 25th May 2010, 09:29
  2. Drop Links
    By themarbleman in forum Suspension, Wheels & Brakes
    Last Post: 10th April 2010, 20:06
  3. drop bar links
    By cockney16v in forum Vectra C / Signum Car Chat
    Last Post: 5th April 2009, 09:57
  4. Drop links
    By Kcs in forum Vectra C / Signum Car Chat
    Last Post: 19th March 2009, 21:45
