Results 1 to 10 of 11
Thread: 1.8vvt running lumpy + eml on
    Regular Member Steevo's Avatar
    kent
    Default 1.8vvt running lumpy + eml on
    Hello
    I was driving to my mates house and my vec started to hicup and then the engine management light came on now its running really lumpy. My mate has a mickey mouse diagnostic tool and it said cylinder 4 fault.
    Any suggestions would be very helpful.
    Its a 1.8vvt sri 2007 with 55k
    Thanx Steevo
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 137000
    have you got the code off his reader
    Regular Member JagRigger's Avatar
    Norfolk
    Engine : 1.8 VVT
    Mileage : lots !
    Could be the coil pack
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    Could be spark plugs, either stick a new one in cylinder 4 or swap it with one from another cylinder and see if the miss fire moves when the codes are read.
    kent
    Couldn't get any codes out of it, he didn't really know how to use it and i didn't want to make any more problems. It just said cylinder 4 fault.
    I will try swaping plugs over in the morning.
    Any idea on price for a coil pack
    Thanx steevo
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 137000
    Quote Originally Posted by Steevo View Post
    Thanx steevo
    is yours a z18xel engine
    kent
    Quote Originally Posted by vectra ste View Post
    The little credit card thing says z18xer
    glasgow
    Defo the z18xer engine mate, had the same problem as you this week, Only it was a cylinder 2 misfire used the how2 advice on getting the fault code using the brake and accelerator pedal and ignition key. (makes your eml light flash the code)
    Changed my plugs no change, I needed a coil pack £99 a local motor factors found it hard to get one. Put that on and sorted it out right away, spoke to a mechanic mate who told me these coil packs were designed to rip us off, as they commonly fail.
    He works on BMW's and says most of them have individual coils that can be changed for around £10-15
    kent
    Quote Originally Posted by johnnyw View Post
    Did u have to reset anything after u replaced the coil pack or did the engine light just go out?
    Thanx Steevo
    kent
    Replaced the plugs they were proper crudy and the coil pack problem now sorted.
    Drives like new now can't beleve the difference.
    Thanx for the help
    Steve
  1. No power & very lumpy running 1.9 cdti
    By phil147 in forum Engine & Drivetrain
    Last Post: 19th June 2013, 17:25
  2. running lumpy
    By bert01909 in forum Engine & Drivetrain
    Last Post: 9th January 2012, 15:10
  3. Running VERY lumpy 1.9 cdti 150
    By kevcdti in forum Engine & Drivetrain
    Last Post: 9th June 2011, 08:33
  4. cdti running really lumpy and no power??
    By richiem in forum Engine & Drivetrain
    Last Post: 7th July 2010, 19:16
  5. 1.9 CDTI Lumpy Running at Idle
    By Dazfoz in forum Engine & Drivetrain
    Last Post: 13th April 2009, 18:23
vectra c 1.8 vvt running rough
vauxhall vectra c sri 1.8vvt engine management reset
