Results 1 to 10 of 14
Thread: What do I need now?
    Regular Member aerodynamic18's Avatar
    Aug 2007
    Lisburn, N.Ireland
    Default What do I need now?
    Guys I have just bought a kestrel das6 da polisher only so I need to know what pads to get or anything I need for it? Ie backing pads etc? The blue masking tape and other things. I have the polish ok and things but it just the pads and things looking forward to getting it now
    Regular Member ANDY W's Avatar
    May 2007
    WINSFORD
    Have a word with Mark at Autobrite who is a retailer on here. I have one of these and I use the 3M Pads and use there matching compounds / polishes. Meguiars also do a great range of pads and polishes etc.
    May 2007
    WINSFORD
    Quote Originally Posted by ANDY W View Post
    Also have a look at Gtechniq products as they are the dogs bits matey and I now use all of there products on my car and it looks better than it ever has
    Newport (Shropshire)
    Vehicle : Ford Kuga
    Trim : Titanium
    Engine : 2.0dtci
    Mileage : 1200
    You might also check www.CleanYourCar .co.uk. as well as about everything you need they have their own detailing forum.
    Pads are a matter of personal choice. Messsy, who showed me how to detail mine, uses sonus, but recommended I use Chemical Guys hexologic. have hear Lake Country are ok as well.
    I prefer Meguiars polishes etc, but that also is personal preference. Read on the pads description, some are for light swirls, some heavy scratches, some polishing/glazes, then work out what your paintwork will need - and always, always, start with the lightest polish and pad, then, if needed, go one step down at a time. Never, ever, start with the roughest. I've also bought a snow foam lance for my pressure washer, £39.99 on offer at CYC or Autobrite at present.
    Aug 2007
    Lisburn, N.Ireland
    Well I have chemical guys polish so I have that and it says for machine polishes. What I mean is what will the polisher come with ie a backing plate which u use Velcro pads for or what? Is normal masking tape ok or do I need the blue tape?
    Regular Member fenderguitar's Avatar
    Portadown Co. Armagh N. Ireland
    We could try polishing mine when you get it
    Vehicle : Ford Kuga
    Trim : Titanium
    Engine : 2.0dtci
    Mileage : 1200
    I don't know anyone that uses the blue tape, as far as I know, it masking tape for any areas you don't want polished.
    As for backing pads, depends where you bought it from, CYVC supply with one, I bought an extra, and will probably get the small size as well at some stage. The DAS6 's I've seen )including mine) use velcro to connect the pad to the backing.
    I once thought you had to use "machine polish" but was told here the AG SRP and most others can be applied by hand or DA.
    Aug 2007
    Lisburn, N.Ireland
    yea i just noticed it has a 150mm velcro backing plate so i guess i just need pads that fit onto this then
    Vehicle : Ford Kuga
    Trim : Titanium
    Engine : 2.0dtci
    Mileage : 1200
    Mine came "supplied with two Velcro Backing Plates Size: 125mm ( 5” ) and 150mm (6"), for 5", 6" and 6.5" polsihing pads. Think the small spot detail ones are 4 inch. I went with the DAS6 Pro, as the longer lead looked easier, and a bigger motor can't be bad.
    Aug 2007
    Lisburn, N.Ireland
    i managed to get mine new for £50 so cant be bad to that. ill be asking more questions tomorrow about what order to use my polishes etc lol. i need to get rid of swirls light scratches etc but as i said i have all the needed polishes, scratch removers i need so all i need is the pads and im all set ill pick up some masking tape tomorrow from b&q to cover the black plastics and then ill be all set. im also trying to get a pressure washer and then a snow foam lance to finish off my kit i guess i would need a pad for every polish im using so i dont mix them? it will be a case of a detail day soon where ill clay and everything the car
