Thread: Mas Performance remap
    Regular Member sloper's Avatar
    Oct 2010
    bradford
    Default Mas Performance remap
    Went to Mas Performance today for the DPF removal. EGR disabling and remap on my Signum CDTI 150.
    First job remove the DPF and make a replacement through pipe and fit. Had a look at the DPF, you can see why they can become a big problem, Black bright!
    First RR run- 145 BHP - 341.1NM as standard
    So Ben downloaded the map and another run, now were talking -180 BHP -402.1NM.
    How does the Sig' drive now? Well throttle response is excellent no more hesitation around 1000rpm, the turbo pics up very smoothly and before you know it you knocking 70mph with power all the way. The important bit, i can now pull out of a junction without wondering if im going to need to dip the clutch to get the turbo to pull me away from that bogging. I also noticed the Sig will sit and drive nicely now just above 1000rpm doing 30ish in 5th and will pick up nicely without dropping a gear from 4th at the foot of a hill, like before!
    So far so good. im well happy, cars driving how it should, i dont need to worry anymore about all the ****e clogging up the Boost valve, swirl flaps, or the EGR and all being well should get better MPG. Nice one! cheers Ben!
    South Central England
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    Well sound like very reasonable figures and the graphs look correct. You actually have a little more torque than me at 2000rpm
    lincolnshire
    happy days ! and the price for all this good work is ??
    Oct 2010
    bradford
    Quote Originally Posted by bembo449 View Post
    £360 well spent me thinks
    lincolnshire
    Quote Originally Posted by sloper View Post
    i may just do the pipe mod and get my mate to write the DPF out the ECU ! will still improve my 120 a good bit !
    Feb 2011
    co/durham
    Hi, i have just removed my DPF and taken all the insides out so it is empty... refitted the same and car runs so much better pulls from low down no problem and smoother i could feel the difference straight away , going to wait n see if car trys to regen it shouldn,t but if it does will just get DPF removed from ecu ..
    Regular Member winnie2457's Avatar
    kings lynn, norfolk
    Your car will def go through a regen in te next 400miles and once it does it will go into emergency regen as the dpf will not get up to correct temp this will kill your fuel economy and have a White smoke screen ffrom the back if your car I know as it's happened to me i used to reset the dpf saturation readings on opcom every 200 mile but still caught me out now and then so I swiftly went to Mas to get a map and dpf software removed.
    Hope this helps mate
    Regular Member bangty 1's Avatar
    Sep 2010
    in a box
    Quote Originally Posted by winnie2457 View Post
    all true had it do this for a week and used £50 of fuel for 100mile
  1. MAS Performance Remap
    By amand in forum Diesel Engine related
    Last Post: 29th April 2012, 13:08
  2. MAS Performance remap DONE!
    By unikarl in forum Vectra C / Signum Car Chat
    Last Post: 1st April 2012, 15:59
  3. mas performance remap
    By fjaimo10 in forum Diesel Engine related
    Last Post: 30th November 2011, 11:43
  4. Remap by Mas performance?
    By gumanue in forum Vectra C / Signum Car Chat
    Last Post: 6th May 2010, 20:26
  5. MAS Performance remap
    By hideyspidey in forum Diesel Engine related
    Last Post: 29th July 2009, 13:30
