Thread: scratched disc's
    Regular Member markj23's Avatar
    Aug 2010
    Luton
    Default scratched disc's
    Hi people have a problem quite a few of my son's (12) discs are scratched due to him not replacing them in the boxes when this has happened previously I have given them a rub with glass cleaner and all good, however he has damaged a couple of his best games. So what I need to know is there some thing I can buy that will restore the games or is there a good product that will remove the scratches, apart from making sure he looks after the discs and puts them back in the cases
    xbox 360 if it makes any difference
    Full Member Big-Pete's Avatar
    May 2007
    Home or in the Gym
    96 Post(s)
    Vehicle : Audi Q7
    Trim : S-Line Plus 245
    Engine : 3.0 TDV6
    Mileage : 3023
    Game and Gamestations have a disc repair / restoration service, its supposed to be quite good..
    Here's the LINKY
    Regular Member bangty 1's Avatar
    Sep 2010
    in a box
    yer game did my godsons wii games £2 each but only works once
    Regular Member jimbovectra's Avatar
    liverpool
    Default try this first... as its free..fixed loads of mine
    as long as they are not to badly damaged. i have found that the problem may just be dirt in the scatches rather than the scratches themselves
    lightly wet 4/5 sheets of bog paper
    put a pea sized blob of washing up liquid on it
    rub around the disc with it for about a minute
    then get about the same amount of bog paper and again wet it - repeat the rubbing process - make sure all the washing up liquid has gone (repeat if neccesary)
    once the disc is dry try the disc
    remember to keep the label side as dry as poss
    lastly teach him to look after his stuff :-)
  1. Brake Disc's
    By slipperysam1984 in forum Suspension, Wheels & Brakes
    Last Post: 12th January 2012, 08:38
  2. what size are my disc's?
    By dannydm1 in forum Suspension, Wheels & Brakes
    Last Post: 18th December 2011, 16:19
  3. What size disc's?
    By mishima in forum Suspension, Wheels & Brakes
    Last Post: 9th May 2009, 18:31
  4. What disc's do you have?
    By Leemarksmith in forum Handling & Braking
    Last Post: 27th June 2008, 22:00
  5. 314 disc's and pads
    By chrisgettings in forum Handling & Braking
    Last Post: 23rd January 2008, 18:26
