Results 1 to 10 of 23
Thread: 2011 gets even worse!
    Regular Member R-ford_Vec_C's Avatar
    St Helens
    Default 2011 gets even worse!
    Ok, so after forking out over £700 so far this year I have encountered a new problem :-( spent 5 hours cleaning the motor this morning then nipped to take some bulbs back to Halfrauds whilst on my way there the vent were spraying water onto the windscreen (inside) this problem has now stopped but I niticed there was a puddle in my passenger footwell, popped the bonnet and noticed water running down the back wall of my engine bay, any ideas?
    Regular Member markj23's Avatar
    Aug 2010
    Luton
    scuttle panel drain blocked
    Regular Member Mr Hyde's Avatar
    Feb 2011
    Suffolk
    Or even a leaking heater matrix? Hope it's just s blocked scuttle mate...
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800
    Mileage : 132000
    Quote Originally Posted by R-ford_Vec_C View Post
    http://www.vectra-c.com/forum/showthread.php?t=128337
    i hope this helps
    if it is let us know
    how to get at it
    http://www.vectra-c.com/forum/showthread.php?t=108462
    Full Member Big Sig's Avatar
    Check all of the grommets in that side of the engine bay, under the scuttle panel. If ones loose then water can run down there.
    St Helens
    Boy I love this site, 3 minutes work and problem solved! Unblocked the hole in scuttle panel (which was a nasty job) then all the excess water gushed out the bottom of the engine bay!
    Aug 2010
    Luton
    million dollar question did you blow your heater fan resistor?????
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800
    Mileage : 132000
    Quote Originally Posted by markj23 View Post
    we may hear off him again
    about the resistor pack
    Aug 2010
    Luton
    Quote Originally Posted by vectra ste View Post
    should have done this anyway poll:has everyone cleaned there scuttle tray out lateley
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800
    Mileage : 132000
    glad u sorted it mate.
    vectra ste
    i love it when a plan comes together
  1. White smoke getting worse and worse
    By alphabravo in forum Vectra C / Signum Troubleshooting
    Last Post: 19th March 2011, 01:04
  2. Always someone worse off than you are.
    By SignumPhil in forum The 'Off Topic' room
    Last Post: 9th March 2009, 17:34
  3. Its getting worse..........
    By bobby-tupper in forum Vectra C / Signum Car Chat
    Last Post: 27th January 2009, 18:23
  4. Could it of got much worse?
    By Gregg in forum Vectra C / Signum Car Chat
    Last Post: 26th November 2008, 12:54
  5. From bad to worse
    By VECTRA HEAD in forum General Chat
    Last Post: 6th March 2008, 19:07
