Thread: Possible intercooler damage - 2.2 DTi
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    Default Possible intercooler damage - 2.2 DTi
    G'day all.
    Could hear a whistling/roaring noise when on boost driving home yesterday, got louder with the turbo. Suspected a boost pipe to have gone but no they're all fine, had them off and had a good look. Bit of a sod to do but needed to be checked - all fine. Spoken to my dads friend who is the head mechanic at the local Volvo dealer and has been doing our cars for the last 20 odd years, he said if it's not the boost pipes, it might be the intercooler has cracked slightly. There's some black smoke on acceleration and it feels a little down on power. Everything else has been checked over with no faults.
    So guys, sound like an intercooler has started to go? Car has 200k miles on it. I can get a front mount one from a bloke in college that has one for sale for considerably less than a VX one so I might go for that. What is the max boost pressure from the 2.2 DTi?
    Cheers.
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    *bump*
    morecambe
    28 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    any split boost pipes
    West
    get someone to hold the revs down while you check all the boost hoses, leaks will be apparent
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    Been out to get it hot and held the revs on the drive with the bonnet up. Can hear a roaring sound but there doesn't seem to be any splits in the boost pipes.
    Regular Member Innes's Avatar
    Plymouth
    It sounds like an inter cooler hose split. Give the hoses a squeeze as the cracks can be hard to see otherwise. The left and right hoses do go on the2.2 and 2.0 DTI's. Vauxhall used crap rubber and they get eaten away from the inside out by the oil vapour from the turbo. You can get replacement hoses from eBay for £63 each. If it's the right hand pipe you could make your own like I did:
    http://www.vectra-c.com/forum/showthread.php?t=116528
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    I have dude. The pipes have been off, checked, put back on and the revs held on boost. Pipes are ok but can hear air escaping somewhere, just can't find it. Made sure everything is on tight.
    Regular Member peadar's Avatar
    Aug 2007
    in the glens of Antrim N Ireland
    Vehicle : SRI
    Trim : FULL LEATHER
    Engine : 2.2 DTI
    Mileage : 197,000
    mine does the same and i cant find any splits at all , if it is a split hose surely it should be going into limp mode and i have changed all vacum hoses and 3 had slpits but no different
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    I guess it depends on how much it's losing boost by, if it's not enough for the minimum threshold then the engine won't go into limp home mode. I'll keep an eye on it. Something just doesn't feel quite right.
    Regular Member booker413's Avatar
    West sussex
    have you checked the two lower boost pipes that conect intercooler to down pipes?
    i have a pair if you need them
  1. Damage.
    By vaughaney68 in forum Suspension, Wheels & Brakes
    Last Post: 20th February 2012, 20:34
  2. Standard intercooler v front mount intercooler
    By tommytonguedj in forum Engine & Drivetrain
    Last Post: 29th June 2011, 09:58
  3. Damage
    By Dodger in forum Comedy & Humour
    Last Post: 1st March 2008, 13:13
  4. More Damage
    By DennisTheMenace in forum Vectra C / Signum Car Chat
    Last Post: 19th July 2007, 08:46
  5. Tow Bar Damage
    By Nidge in forum Vectra C / Signum Car Chat
    Last Post: 23rd May 2007, 22:07
