Thread: no gears !!! HEELLLPPPPPP
    Feb 2011
    cardiff
    Default no gears !!! HEELLLPPPPPP
    I got a 2.2 vectra elegance auto it starts and runs perfect but just will not select any gears ,D R, or even tiptronic there are no lights on dash at all nor has there ever have bin so im at a bit of a loss on what it cud be any ideas plzzzz
    Feb 2011
    cardiff
    by the way its an auto
    Regular Member Jezzy's Avatar
    S.E
    Could be contamination of the transmission oil with water from the cooling system. Happens to quite a few Vecs due to failure of seals that keep the two fluids separate.
    Regular Member MysteryElite's Avatar
    Feb 2007
    North Somerset
    No lights or codes, first thing I'd check is that the linkage is OK to the top of the gearbox, could be somethings come adrift?
    Ely, Cambridgeshire
    61 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    Just out of curiosity, you havent just jump started the car have you? The tiptronic gear box is a little sensitive to that, had it happen before with my ex's car. Starting the engine and leaving it running for a short while, then switch it all off again and wait an hour usually gives it all time to reset itself.
    Apparently it's fairly common with that type of gearbox. But I've only ever come across it the once on her car.
    Sep 2009
    i believe its going to be the speed senser if its only selecting some gears.
  1. getting gears
    By mitch in forum Engine & Drivetrain
    Last Post: 8th December 2010, 01:43
  2. How many gears
    By Jason123 in forum Vectra C / Signum Car Chat
    Last Post: 8th February 2009, 10:21
  3. gears
    By howey in forum Engine & Drivetrain
    Last Post: 27th May 2008, 19:54
  4. how many gears in the 1.8 vvt?
    By jaff in forum Vectra C / Signum Car Chat
    Last Post: 15th January 2008, 19:09
  5. no gears - help!
    By Digital_kid in forum Engine & Drivetrain
    Last Post: 23rd May 2007, 13:53
