Page 1 of 9 123 ... LastLast
Results 1 to 10 of 82
Thread: Airbox mod.....part deux!!! (rip off of VXR280 airbox mod)
    Liverpool
    Default Airbox mod.....part deux!!! (rip off of VXR280 airbox mod)
    Well been pottering today and finally gave this a go, been contemplating it for a while
    Bored a 50mm hole into the top of airbox (opposite side to cold air intake), to try and keep it away from any water
    Fitted a modified vent into the hole, and bonded into place,
    Seems to pull stronger in second gear mostly, but througout the range and when under heavy load, but have only been for a short run, will be driving over to manchester tomorrow and back sunday (hopefully in time for next northwest meet) so i will report back then about how it is on motorway and also if any impact on mpg, but at the moment does look like its a little better on short runs
    Regular Member Chris06v6's Avatar
    Fife
    I'll be watching with interest for the results of this, love tinkering
    have you put any cold feeds near to the new vent?
    Regular Member jatint's Avatar
    Kilmarnock
    IM new to vectras so i cant be sure but surely that just lets hot air from engine in???
    I.E Heat soak?
    Regular Member instinct25's Avatar
    merseyside
    does it make any difference in noise ? are they facia/soffit vents ? got loads of them in work ,may have to swipe one mmmmwahahahahaha
    Liverpool
    Quote Originally Posted by Chris06v6 View Post
    Nope, I just have the same cold air feed at the front
    Quote Originally Posted by jatint View Post
    I.E Heat soak?
    The cold air feed is still there so it is just providing more air mass, plus I have got it at the back so it should stay away from hot air, and car lives on motorway so I can see heat soak being an issue as the standard feed is still there, I would only worry about heat soak with a cone filer
    Quote Originally Posted by instinct25 View Post
    Turbo noise is louder, and a little more grunt on tick over
    Oh yes just a sofit vent
    merseyside
    good news on the turbo noise mate , wish i had a turbo lol. does it make more of an induction kit type noise if you drill holes in the bottom like you have?
    Liverpool
    Yeah more of an induction noise
    I haven't drilled any holes in the bottom, they are just drain holes
    Fife
    Quote Originally Posted by paul_sri150 View Post
    just a sofit vent
    got a few of them knocking round the garage, wonder what i'll be up to tomorrow
    Kilmarnock
    Might do this myself then
    Northampton
    Engine : A20DTH
    Mileage : 88000
    So the VXR's have a similiar set up already?
    No harm in trying it as you can always tape it up if you wanted to. Looks like another mod
  1. Airbox mod Part 22 - Electric Turbo??
    By TonyP2020 in forum Petrol Engine related
    Last Post: 18th January 2012, 20:36
  2. Would the vxr280 airbox mod work on a diesel?
    By paul_sri150 in forum Vectra C / Signum Car Chat
    Last Post: 26th November 2010, 20:30
  3. airbox mod part???
    Last Post: 17th July 2010, 03:49
  4. 2.8T Airbox
    By parapaul in forum Petrol Engine related
    Last Post: 16th August 2008, 21:21
vauxhall a20dth airbox mod
vectra vxr drilled airbox www.vectra-c.com
