Page 1 of 4 123 ... LastLast
Results 1 to 10 of 31
Thread: Clutch problems V6 CDTI
    Regular Member chilly51967's Avatar
    Nov 2010
    Sutton Coldfield
    Default Clutch problems V6 CDTI
    Hi - any advice gratefully received!
    When pulling away in 1st gear; I get a 'flat spot' of acceleration (pressing accelerator down further has little affect). As a result, acceleration is pants. This is intermittant and only accelerates correctly, occasionally.
    When changing to 2nd gear and depressing the clutch, as soon as the clutch pedal goes down to the top of the bite, the car lurches forward and takes off - making a smooth gear change impossible.
    What I have found is that when the the 1st gear acceleration is flat; if I keep the clutch pedal down to the top of the bite and 'ride the clutch' a little, the car responds brilliantly - i.e. acceleration is instant and progressive. I can hit the flat spot; depress the clutch; accelerate and depress the clutch again to return to the flat spot!
    Is this a clutch issue, or is there some form of sensor problem that's fooling the ECU?
    Thanks in advance,
    Ian.
    Regular Member BigWilko's Avatar
    Jan 2010
    Barnsley
    Engine : 3.0 CDTI
    Quote Originally Posted by chilly51967 View Post
    Thanks in advance,
    Ian.
    hmmmm, Don't think it sounds right, certainly not like mine. I've just gone from a 120CDTI to the V6 CDTI so everything seems fast. I was concerned that my clutch was 'funny' but as i'm driving it more it just seems that it's a 'different car' issue.
    Mine suffered something very similar to this, reported it numerous times and no fault found
    On mine I would be in a high gear, then require to a low gear to overtake
    Push the gas, but get loads of revs and no increase in speed, then suddenly it would apply
    The clutch eventually gave up
    There is a Field Remedy for incorrect lubrication on clutch / gearbox
    Visit dealership and discuss
    Nov 2010
    Sutton Coldfield
    Thanks Wilko and M8, for your replies.
    I got the car thru Evans Halshaw and it's already had one field remedy applied (ECU update) under warranty, as I was suffering issues at 1500 revs.
    That time, I had to tell them what to do to fix the issue - thanks to this forum! Funny how they can't find any fault when they're paying for it. Looks like I might have to demonstrate the issue to them.
    Thanks, again, and if anyone else has heard of something similar, then all ammunition will be useful.
    Not aware of that one, do you have the field remedy number?
    Field Remedy 1957 refers to a EMS update on completion of the fitting of the upgraded SCVs to the fuel pump, that's only one I am aware of
    Nov 2010
    Sutton Coldfield
    1957 is the one that was applied. However; I think that the issue is returning, so it looks like they'll kop for the SCVs too. 3 month's warranty is about to expire...
    That was pointless, it should only be applied once the uprated SCV have been fitted
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Not true as the new EMS just alters the way the engine revs in neutral, which in return aids gear changes. The only thing connecting, so to speak, the SCV's and new EMS is that the new EMS has the fault code for failed SCVs...the old EMS would give UNKNOWN FAULT CODE (fuel related).
    Field Remedy 1957, the EMS update is solely to be used AFTER the uprated SCVs have been fitted
    This is clearly marked on TIS
    Equally, VX have a disclaimer that in the event that only the EMS is applied that the retail outlet (ie dealership) remains liable for any subsequent repair costs
    The main benefit of the EMS update is to report on fuel errors, which the original EMS does not, ie when the SCV is partially blocked the warning light comes on, thus preventing any damage and is diagnosed quickly and early
    Nov 2010
    Sutton Coldfield
    Thanks guys.
    I've booked it in, on the basis of the 'clutch issue', but I'm going to update them with the revs issue again. On he basis that I told them that the revs symptoms seemed to match Field Remedy 1957 and the applied the EMS (not ECU as I said!) only, then it would seem that they (Evans Halshaw) have left themselves open to be responsible for any potential replacement of SCVs.
    At the end of the day; I've got a car that I really like (it's my first VX since my first car (a Mk 1 Astra 1.2) and they should make sure that everyting works as it's supposed to, before the warranty runs out!
  1. Clutch problems ?
    By hippo in forum Engine & Drivetrain
    Last Post: 4th June 2012, 22:39
  2. clutch problems
    By sebadee in forum Vectra C / Signum Troubleshooting
    Last Post: 23rd January 2011, 23:27
  3. Clutch problems
    By emmysnail in forum Engine & Drivetrain
    Last Post: 25th April 2010, 09:26
  4. Clutch Problems
    By R13hard in forum Vectra C / Signum Car Chat
    Last Post: 19th April 2008, 14:47
  5. 1.9 Cdti Flywheel/clutch Problems
    By CHRISSMART41 in forum Engine & Drivetrain
    Last Post: 20th October 2007, 16:00
