Results 1 to 2 of 2
Thread: Climate Control Blower Problem
    Regular Member 24vElite's Avatar
    Rustington, West Sussex
    Default Climate Control Blower Problem
    Help - 54 plate Signum Elite (pre-facelift) with climate control. On way home last night blower suddenly started blowing at full level. No response from the central fan speed control dial or either temperature control dials. Pressing the max defrost button increases fan speed slightly and pressing auto reduces it again slightly.
    Blower remains blowing even with ignition off and key removed. Only way to switch off is to pull the 30A air con fuse from the passenger dash. Other fuses relating to interior fan have no effect.
    I know there is a resistor ptoblem with non climate control cars but is there a similar problem with ECC cars?
    Any help gratefully received.
    Feb 2013
    Peterborough
    Vehicle : Vectra Design
    Trim : Half Leather
    Engine : 1.9CDTI
    Hi, Did you find out what caused this as I have the same problem.
  1. Climate control problem help!
    By CallumHill in forum Vectra C / Signum Troubleshooting
    Last Post: 18th December 2012, 23:20
  2. Climate control problem
    Last Post: 11th December 2012, 23:58
  3. Heater Blower not working on Climate Control Model
    By wifesgotasignum in forum Vectra C / Signum Troubleshooting
    Last Post: 14th June 2012, 09:54
  4. Is blower motor resistor pack same on climate control models?
    By Partyvan in forum Electrical & ICE (including SatNav)
    Last Post: 26th April 2011, 13:39
  5. Another climate control problem
    By 24vElite in forum Electrical & ICE (including SatNav)
    Last Post: 8th May 2008, 21:08
