Thread: water coming into car
    Feb 2011
    wales
    Default water coming into car
    This is my first thread so I hope it's in the correct forum.
    The passenger footwell and rear near side footwell has water saturating the carpets after the rains we've had of late. I cant seem to find where this water is coming from...any suggestions.
    Im not sure if its connected but after the snow we had at the end of last year the plastic engine cover on the underside of the car was damaged and removed by my local garage. It was not replaced as I was told it serves no function!
    Any suggestions, thanks
    Full Member gibbon7000's Avatar
    lincs
    Have a look at this thread http://www.vectra-c.com/forum/showth...=1#post1234916. It's most probably blocked and needs clearing out. 2 min job. HTH.
    My other car. 1972 1641cc slammed beetle. On the road finally!!
    Regular Member wallace78's Avatar
    Dec 2010
    belfast
    yeah thats wat happened 2 mine once cleared thats it sorted!!!
    Feb 2011
    wales
    Thanks guys Ill do that.
    Dec 2010
    belfast
    make sure the rubber drain plug is pulled into place just under the pollen filter!!!!
    Feb 2011
    wales
    Hi guys. I did as suggested, unblocked the plug and changed the filter but still getting some water in. Same area, passenger and rear footwell. Any other ideas what I should be looking for?
    I've been told it should make no difference but since the plastic underside cover was removed after being damaged I've had this problem. Could water be coming from underneath?
    Regular Member chrisknights's Avatar
    Feb 2011
    brighton
    its a pain of a job , but glove box will have to come out and front seat , and get some one to pull water on an area for a while and try to pull back carpet as well and get a torch and see if you can spot any water coming through ,
    another thing have you got a sunroof ??
  1. What colour is your radiator water bottle water? and head gasket.
    By Jow20 in forum Vectra C / Signum Car Chat
    Last Post: 26th January 2011, 21:39
  2. water coming out of resovoir like a geaser
    By ade hammond in forum Vectra C / Signum Troubleshooting
    Last Post: 29th August 2009, 08:57
  3. I'm Coming Down With Something
    By VauxVeteran in forum The 'Off Topic' room
    Last Post: 1st April 2009, 00:36
  4. water coming in car
    By topman825 in forum Vectra C / Signum Car Chat
    Last Post: 1st June 2008, 21:54
  5. Coming soon !!!!!
    By markm in forum Cars for sale
    Last Post: 11th August 2007, 13:41
