Thread: Tapping noise from engine
    Regular Member Teapot's Avatar
    woodbridge, suffolk
    128 Post(s)
    Trim : Design+
    Engine : 1.9 CDTI 150
    Mileage : 101000
    Default Tapping noise from engine
    Not really a big problem yet, but over the past year or so my signum 1.9cdti engine has started making a tapping noise from the engine, which has gradually worsened. It is very audible when cold, and quietens when the engine has warmed up but can still be heard faintly during accelleration.
    At first I suspected worn camshaft or a dicky valve lifter, but I have noticed that the noise disappears on the overrun (i.e. when no fuel is being injected), so its probably not cam/valve noise as in my experience this would be the same regardless of engine load.
    Recently I have also noticed a slight misfire at idle, particularly when the engine is cold. Is it possible that an injector on its way out could cause both these symptoms? If so, how can i find out which one? opcom is not showing any fault codes at the moment?
    The car has done 116k...
    Regular Member Mopar Man's Avatar
    herts
    If it sounds like a diesel Knock, Get the injectors overhauled at a diesel specialist.
    woodbridge, suffolk
    128 Post(s)
    Trim : Design+
    Mileage : 101000
    Quote Originally Posted by Mopar Man View Post
    Thanks, I didn't realise that common-rail injectors were serviceable. I thought that the only solution was to identify which one had become faulty and replace it with a new one.
    How much should I expect to pay for the set of 4 to be reconditioned?
    herts
    Quote Originally Posted by littleteapot View Post
    About £40 each
  1. Tapping Noise From Engine
    By viper8 in forum Engine & Drivetrain
    Last Post: 13th January 2012, 12:34
  2. Tapping noise
    By james tierney in forum Vectra C / Signum Troubleshooting
    Last Post: 7th April 2010, 12:28
  3. tapping noise
    By luke.oldham in forum Engine & Drivetrain
    Last Post: 2nd March 2010, 11:50
  4. Tapping Noise
    By jay146 in forum Vectra C / Signum Car Chat
    Last Post: 24th January 2008, 15:28
  5. Tapping noise at 60-70 mph.
    By Andrew Hambridge in forum Petrol Engine related
    Last Post: 31st July 2007, 15:00
vectra c noisy petrol injectors
tapping noise from engine vectra c
