Thread: more engine problems
    Nov 2005
    northern ireland
    Default more engine problems
    right guys this time im getting judders when driving a few times the limp mode has flashed on and off several times. it seems to lose power tyhen pick up again. seemed to b running fine this morning but the same thing happened 2nite just driving along and i think between 1500 and 2000 revs, could it b turbo boost sensor, eg r 3rd injector im just looking a bit of help b4 i have to bring it to the garage
    many thanks...
    Nov 2005
    northern ireland
    4go to say it a 1.9cdti 2004 model
    Nov 2005
    northern ireland
    Default bump
    bump
    Regular Member pattz123's Avatar
    Motherwell
    14 Post(s)
    Vehicle : Vauxhall Vectra Estate
    Trim : SRI
    Engine : 1.9 CDTI 150
    Mileage : 83k
    Could possibly be the throttle position sensor.http://www.vectra-c.com/forum/showth...45#post1338145
    Motherwell
    14 Post(s)
    Trim : SRI
    Mileage : 83k
    Quote Originally Posted by pattz123 View Post
    Your symptoms seem to be consistent with this identified fault. Seems to be an issue with cracked solder joints on the throttle pedal position sensor circuit board on 2004 and some 2005 1.9 cdti's. Check out this sticky http://www.vectra-c.com/forum/showthread.php?t=118784 Mind let us know how you get on.
  1. Help please engine problems
    By 11mallard in forum Engine & Drivetrain
    Last Post: 6th April 2012, 18:54
  2. engine problems 2.0 dti
    By adriches in forum Engine & Drivetrain
    Last Post: 30th July 2011, 10:38
  3. 2.0T Engine problems...?
    By n_hudson in forum Engine & Drivetrain
    Last Post: 4th February 2009, 17:43
  4. Engine Problems
    By Madmarky01 in forum Engine & Drivetrain
    Last Post: 1st April 2008, 12:44
  5. 1.8 SRI engine problems....
    By bigd1975 in forum Engine & Drivetrain
    Last Post: 12th May 2007, 19:59
