Thread: EML 2.0T Lambda or CAT
    Regular Member a1ant's Avatar
    Jul 2010
    England
    Vehicle : 2.0 Turbo
    Engine : 2.0 Turbo
    Default EML 2.0T Lambda or CAT
    Hi guys,
    On my way to work this morning, and whilst slowly moving towards a roundabout, the EML came on.
    Got home and put it on diagnostics and came up with the following:
    - P0138 - 02 Sensor Circuit High Volts (bank 1 sensor 2)
    - P0420 - Catalyst Efficiency below threshold (bank 1)
    Thought at first it was going to be a straight forward "duff lambda sensor" BUT:
    When looking at the live data, the 2nd lambda sensor was stuck reading 1.250 mV. I believe the EML is activated if it stays above 0.999mV for a length of time. The front O2 sensor reading was moving up and down as per normal.
    I then reset the codes thinking I would give it one last chance before buying a new lambda, and the sensor suddenly sprang to life, with the Mv fluctuating nicely.
    I have since been on several slow and "spirited" drives and the EML has not reappeared and the logged data shows the O2 sensor seems to be working correctly.
    Anyone have any ideas? Im reluctant to say its "just one of them things"
    Is it likely the O2 sensor is on its way out? or CAT?
    Thanks in advance,
    Alan
    lincolnshire
    this is sensational ! a problem on a 2.0 T ! are you sure your not just sick of not having anything to post about ?? lmao
    lincolnshire
    Quote Originally Posted by a1ant View Post
    Hi guys,
    Thanks in advance,
    Alan
    could just be a hiccup !? i'd worry when it stays on as afterall you cant fix what isn't broken !
    Oct 2006
    Waterloo, Liverpool
    Trim : SRI NAV XP
    Engine : 1.9 CDTI 150
    Mileage : 72K
    Quote Originally Posted by bembo449 View Post
    As a former 2.0T owner I would agree. If it doesn't re-occur it is a glitch. Glitches are not uncommon on all engines.
    Full Member Caveman_nige's Avatar
    Jun 2009
    South Coast
    Vehicle : Vectra and a Signum
    Engine : Z18XE,Z19DTH,Z20NET
    I would take it out on the motorway and thrash it to clear the crap out of the cat..
    Regular Member Jezzy's Avatar
    S.E
    Maybe use some Cataclean as well. http://cgi.ebay.co.uk/Cataclean-Cata...item4156bdd66d
    Regular Member Bullylad's Avatar
    Bolton
    I have just posted a topic in the 'general chat' section about a product that got my dad's motor through the MOT emissions test for £10. Have a look at that?
    Regular Member Keefyb007's Avatar
    Jan 2010
    Berkshire
    I've got the same P0138 at the moment, service coming up so been driving with same code for 3 weeks. No biggy just a sensor. I cancelled it with my Fault code reader and it came back a couple of days later.
    Will sort it at service.
    Jul 2010
    England
    Vehicle : 2.0 Turbo
    Engine : 2.0 Turbo
    Hi guys,
    Thanks for all the replies! The EML stayed off for a few days, and then came back on again, then stayed off for a day then back again.
    P0138 Keeps returning, not had P0420 again since the first time.
    On live data logging, the 2nd O2 sensor keeps sticking at 1.265v every now and then, and this is what brings on the EML. SO looks like ill need a new lambda.
    Rubbish vauxhalls, waste of money, crap cars etc etc all that and the other lol. ONLY JOKING. Am picking up a new lambda in the morning so hopefully all will be back to normal
    Thanks,
    Alan
    Regular Member accveccysriturbo's Avatar
    Jul 2010
    west mids
    I can vouch for the cataclean used it in mine to declog my cat along with an Italian tune down the m42 lol.
    The Forte products are good from what I've established also.
  1. Intermittent Lambda ?
    By JagRigger in forum Engine & Drivetrain
    Last Post: 6th January 2013, 08:11
  2. Lambda sensors...
    By nikroc in forum Engine & Drivetrain
    Last Post: 29th November 2012, 21:56
  3. Cat Or Lambda
    By Tam80 in forum Vectra C / Signum Car Chat
    Last Post: 6th July 2011, 21:03
  4. Lambda help
    By Barnes in forum Vectra C / Signum Car Chat
    Last Post: 28th January 2010, 20:42
  5. Lambda
    By VECTRAMAN in forum Vectra C / Signum Car Chat
    Last Post: 14th January 2009, 10:33
vectra 2.0 turbo p0138
o2 sensor reading 1.250
