Thread: Newbie with in need of a little help!
    newcastle
    Default Newbie with in need of a little help!
    hi sorry its my first post and asking for help i have a 2.2 vectra sri 2003
    i have had it about a month and abs or traction control dont work i dont even get a light when u turn the key to position 2 i have checked the fuses IN THE ENGINE BAY and they are all fine
    i have had it on the diagnostics and came back with
    p1390 left wheel speed sencer
    P1613 Immobiliser No Or Wrong Signal Immobiliser
    U2108 CAN-BUS no Communication with ABS/TC
    U2139 Lost communications CIM steering column module
    u2105 no communication with ecm
    u216 no communication instrument control
    any help will be grate thanks david
    Full Member Big Sig's Avatar
    Try unplugging the abs in the engine bay and cleaning the plugs contacts. Could be dirty. Also it looks like you may need a new hub/sensor on the wheel.
    newcastle
    thanks iv tryed cleaning the abs plug and a bit wd40 and no luck iv just ordered the wheel bearing hub kit
    Regular Member leonvectrac's Avatar
    south shields
    Areet welcome to vectra-c !
    newcastle
    Quote Originally Posted by leonvectrac View Post
    cheers
    newcastle
    was abit bord the day so i took clocks out and found some one had covered the leads in black stuff so u could not see that the lights are on hopfully the new wheel bearing hub kit will turn them both out Attachment 38590
    thanks for the help
    Regular Member TimTay's Avatar
    Nov 2010
    BRECHIN
    lucky me! i just got black duck tape!
  1. newbie asking newbie question :-)
    By gavatron in forum Engine & Drivetrain
    Last Post: 6th February 2012, 10:39
  2. Newbie
    By bigjjfaetheyy in forum Introduce yourself.
    Last Post: 2nd October 2009, 08:57
  3. Newbie.
    By Martinlw in forum Introduce yourself.
    Last Post: 1st October 2009, 05:46
  4. Newbie
    By VectraAlan1888 in forum Introduce yourself.
    Last Post: 16th September 2009, 19:02
  5. newbie.
    By signum@37 in forum Introduce yourself.
    Last Post: 3rd August 2009, 12:25
