Thread: window deflectors
    wigan
    Default window deflectors
    hi all as any 1 fitted any of these fit mine then window wont go up any info would be very grateful
    Vehicle : Signum 2.0 DTi
    Trim : Elegance/Elite
    Engine : 2.0DTi
    Mileage : 73350
    Which ones have you got the genuine vx ones with the u clips or the after market ones with stick on tabs/tape
    and still loving it
    wigan
    Default window
    airvit got u clips aswell with them used of ebay £20 do u have any on yours
    Sep 2009
    midlands
    i have them on mine mate and they are fine
    Regular Member 0uT1aW's Avatar
    Aug 2010
    York
    Fine on mine bud, got the heko with tape and metal clips
    Regular Member farley2708's Avatar
    antrim n.ireland
    Default wind deflectors
    heko ones on my vectra,the same on the wifes sri 160 insignia,£78 quoted for vx,£20 on fleebay,look just the same as vx,got the 'u' clips in aswell as the tape
    Engine : 2.0DTi
    Mileage : 73350
    Sounds as if the heko ones have changed they used to be just stick on tabs , but they did have a habit of falling off so sounds like they have added the u clips . to the op prioving you have fitted the u clips on the inside then there should nt be a problem
    and still loving it
    Regular Member jatint's Avatar
    Kilmarnock
    I have team Heko ones from LMF with U clips and tape, Fitted in 30 seconds and are spot on.
    Make sure the U clip goes in properly, (the wee Jagged bit should bite into the rubber and you shouldnt be able to see the clip if its fitted properly,)
    I also fitted my mates and it took about 5 times for his little U clip to bite into the rubber properly and be hidden. as his kept falling out, It was cold so i heat up the rubber a little, i dont know if it helped or not tbh but it worked
    wigan
    Default window reflectors
    thanks all will give it another go
  1. Need help with my window deflectors ?!?!?
    By mark_647 in forum Bodywork & Interior
    Last Post: 27th April 2010, 22:07
  2. wind deflectors
    By deg in forum Styling
    Last Post: 25th October 2008, 13:52
window guards for vauxhall vectra 08 that window wont go up
