Thread: Another EGR valve question
    Regular Member aerodynamic18's Avatar
    Aug 2007
    Lisburn, N.Ireland
    Default Another EGR valve question
    guys i have a 1.9cdti 150bhp engine. i dont think that i have a problem with my egr however if so many ppl are blanking it off i fancy doing it cause anything to help performance will be good so if i get the plate and gasket from fiat and remove the egr what do i do with it once the plate is fitted? i mean do i unplug and set it aside or what. sorry for a repeat question. should i do this or not bother?
    stockport
    Arrow
    Quote Originally Posted by aerodynamic18 View Post
    I personally,wouldn't use the Fiat gasket,some members have had problems with them.I have used the oval 2mm aluminum gasket you can buy off ebay,(£3),with an 8mm hole drilled in the centre.It stops most of the exhaust gases from getting into your valve and keeps the EML off.So far,I've had no problems whatsoever.Fitting it at the inlet side is a lot easier as well,you just have to loosen the 4 body bolts on the EGR so you can get it in place,and,you don't need to use a gasket.Just make sure that you don't over tighten them when you are fastening it all back together again. FELIXX.
    Regular Member peadar's Avatar
    Aug 2007
    in the glens of Antrim N Ireland
    Vehicle : ELITE
    Trim : FULL LEATHER
    Engine : 1.9 CDTI 150 BHP
    Mileage : 87,000
    the blank gaskets just replace the old ones you have to refit the egr valve (i think this is what you mean )
    Aug 2007
    Lisburn, N.Ireland
    i guess i could fit it and then if any problems put it back to normal then? will try and clean boost sensor tomorrow and see how dirty it is and then i think that will help me decide
  1. 2.2 Direct EGR valve question
    By andrewleighton in forum Engine & Drivetrain
    Last Post: 27th June 2012, 23:31
  2. EGR Valve question about cleaning
    By steeley7 in forum Engine & Drivetrain
    Last Post: 23rd April 2012, 17:09
  3. EGR Valve question
    By CH-VECTRA-ELITE in forum Engine & Drivetrain
    Last Post: 8th July 2011, 16:11
  4. Swirl valve question
    By gaz1965 in forum Vectra C / Signum Car Chat
    Last Post: 26th May 2011, 17:23
  5. EGR Valve Cleaning Question
    By corderz in forum Diesel Engine related
    Last Post: 31st January 2011, 21:57
