Results 1 to 10 of 21
Thread: EGR on 120 CDTI
    Mar 2007
    Hull
    Default EGR on 120 CDTI
    Sorry I have spent about an hour searching the previous posts on this. I am looking for a pic of were the EGR is on my 120 CDTi I have found one of the 2.2dti but it doesnt look like mine.
    I posted the other day mentioning I had a problem with my spanner and EML coming on. This problem has stopped now I took car in for an MOT today anyway and the guy mentioned he'd seem similar problems with vectra when using redex and suggested running the tank down and filling up again it should be ok.
    However, the car is seeming bumpy now when accelerating at low revs the turbo kicks in and it flys! I have done some searching and people have suggested cleaning the boost valve and the EGR both of which I have read up on and im going to take it on. I cant find it though haha.
    help?
    Thanks Rob
    scottish region
    dont have picture but if u take engine cover off its at the back of engine block passanger side had this problem light would come on now and again for two months then permanant changed egr valve and fine now
    Mar 2007
    Hull
    Smashing thank you just can't afford another garage session this month
    Rob
    stockport
    Arrow
    Quote Originally Posted by vectrac150cdti View Post
    It's at the back of the engine,where the large rubber hose comes up from the turbo ducting,ends.The oval metal flexi hose collar,is held onto it by two allen bolts.Then there are four main bolts holding it onto the manifold /body,together with an electrical locking connector with a yellow safety tab.Make sure you recover ALL the gaskets when you're removing it. FELIXX.
    Regular Member John35's Avatar
    Jun 2007
    in a white box
    lincolnshire
    Quote Originally Posted by robhullfury View Post
    help?
    Thanks Rob
    i very much doubt that cleaning the EGR will change anything bud ! i n my experience a new EGR is the only guaranteed way of ruling it out of any running probs !
    Mar 2007
    Hull
    Thanks for all the help guys
    It's a strange problem the engine struggled to start this morning but once it started was jumpy. I parked it up this afternoon before work it started fine but there was no considerable power til 2.5k revs then it really took off as the turbo wound up. Any ideas ???
    Confusing... Once warm it doesn't seem as bad though.
    Rob
    lincolnshire
    Rob
    had a 150 with this exact problem and no codes to work from ! swapped EGR for a new and da daa ! sorted !
    Mar 2007
    Hull
    sounds promising that this could be the problem then.
    Im abit skint at the moment having laid out 800 quid on this car in the last 3 months its starting to sap me money up.
    ill try the 'cheaper' option first then if its no good ill go down the replacing road im gonna clean the boost valve at the same time. IF the rain holds off ill have a go tomorrow.
    Thank You All. Ill let you know how I get on.
    Rob
    stockport
    Exclamation
    Rob
    Blank it completely at the oval collar and fit a 2mm aluminum gasket.That should tell you once and for all if it's the EGR.Your EML light comes on but you get a power increase down the lower end of the rev range.
    Check it out,you can make your own aluminum blanking gasket or get one off ebay for £3.Then make your mind up what you want to do.FELIXX.
  1. Weird noise from Signum CDTI 1.9 CDTI (150)
    By oneightycd in forum Diesel Engine related
    Last Post: 22nd June 2007, 22:27
  2. CDTi 120bhp Vs CDTi 150bp
    By bennyk in forum Diesel Engine related
    Last Post: 6th December 2006, 23:45
  3. CRD2 Tuning Box for V6 CDTi or 1.9 CDTi
    By The Doc in forum Parts for sale
    Last Post: 20th October 2006, 21:51
