Thread: ABS Light!
    Regular Member F33F33's Avatar
    Nov 2009
    Preston
    Vehicle : Insignia
    Trim : SRi VX-Line RED
    Engine : 2.0CDTi
    Year : 2012
    Default ABS Light!
    Hello,
    I was wondering if anyone could help me, I have searched the site but not found the exact same problem as mine!
    The ABS light came on recently (during a dry day) and then wouldn't go out. I took a trip to Penfold's house to investigate the issue which reported back as "Front left ABS sensor low voltage or open circuit" which we decided that a new front hub from VX would do the trick. Part ordered £110 and was fitted today to find the light is still on and reporting the same error even after being cleared.
    So £150 wasted due to inproper fault readings.
    The garage I took it to suggested checking over the abs wires next then if that fails looking at a new ecu. The car runs perfect and just had a major service though
    Does anyone have any ideas or know of know issues regarding my problem?
    Sadly a lite ABS light is an MOT fail so it needs to be sorted!
    Regular Member mark1976's Avatar
    Barrow on Humber
    Hi mate,
    Deffo check the wiring to the n/s/f hub between the connector in the the wheelarch and the hub. Start at the connector nearest the hub, strip back the outer covering from the harness and about half way up you will probably find a patch of wire that has gone green! Cut this bit out and solder the wires back together and then insulate them, this should solve your problem. HTH,
    Regards Mark.
    Nov 2009
    Preston
    Vehicle : Insignia
    Engine : 2.0CDTi
    Year : 2012
    Will that require the wheel and hub off again to check? ;(
    Barrow on Humber
    Hi, should only require the wheel off, unless you have 19's then you probably wont need to remove them.
    By Shadrack in forum Vectra C / Signum Troubleshooting
  2. Replies: 4
    Last Post: 18th August 2012, 08:58
  3. Replies: 17
    Last Post: 16th August 2012, 10:07
  4. No throttle, traction control light, engine management light
    By si260188 in forum Engine & Drivetrain
    Last Post: 9th May 2010, 21:45
  5. Fitted rear light,illuminated sunvisors and map reading light
    By glenboy in forum Vectra C / Signum Car Chat
    Last Post: 30th March 2008, 10:51
