Thread: CDTI 150 Warning Light + Poor Performance at low revs. Please Help
    Falkirk
    Default CDTI 150 Warning Light + Poor Performance at low revs. Please Help
    Hi Guys,
    I have a 55 plate (65'000 Miles) 1.9 CDTI 150 Vectra
    Iím looking for a little advice with the following, Please stick with me as I try to explain the best I can
    for about 4 months now when I start my car from cold, The Car+Spanner Light comes on and stays on for a few mins, even if the car is left idling the light will go off after a few mins, Once the car is warm (even after left off for 30 min - 1 hour) the car will start and the light will go out as normal. The car always starts first time, even without a preheat
    Lately, I have noticed poorer performance at low revs, (The wife notices it more as its her who tootles around I normally drive it a little more aggressively but I do have to agree with her). I have had the car serviced last week (Air Filter, Oil Filter, Oil, Fuel Filter) and although the car is smoother and quieter I still think itís not what it should be. I have also run Fuel additives /cleaner through the system but this has not helped.
    Iím not sure if these two issues are related bat am getting a little concerned. Please can someone advice me if there is any checks i can do to resolve this. Thanks
    Regular Member Aikon58's Avatar
    Englandshire
    Vehicle : shatch- sports hatch
    Trim : cheap plastics
    Engine : metal
    Year : 1901
    Mileage : 999
    Glow plugs mate.
    West
    1st issue is likely to be 1 or more of the glow plugs is not working properly...
    2nd issue could be a no. of things, do a search on the forum for EGR valve & swirl bar... these are the most common causes.
    Is the car an auto or an estate, if so it could have a dpf issue.
    hth
    Falkirk
    No dpf on the car, I was originaly thinking Glow Plugs for the error light but the the fact it always bursts into life first turn without preheat put me off that one, Are the Glow Plugs a DIY Job ?
    Englandshire
    Engine : metal
    Year : 1901
    Mileage : 999
    Quote Originally Posted by tilleyedie View Post
    I had the said light on my cdti before,and it still started fine.
    I would be happy to change them myself,i didn't change them myself before,because it was already in the workshop having a service,so i asked the fitter to put them in while the bonnet was open,it's just a case up taking the caps off the top,and unscrewing them,as far as i can see.
    Falkirk
    hth
    Thanks for the advice I have found this Guide for the EGR (I think) http://www.vectra-c.com/forum/showthread.php?t=45867
    still looking for ther swirl bar, I did find a guide for that that replaced the inlet manfold, Is that the case ? or do i just need to look harder, Thanks Again
  1. 1.9 cdti 120 poor mpg and flat spot at low revs
    By mattclayt in forum Engine & Drivetrain
    Last Post: 17th January 2013, 23:36
  2. Black exhaust smoke on high revs, EGR light on, rough idles - 1.9 cdti 150 diesel
    By bananas in forum Vectra C / Signum Troubleshooting
    Last Post: 5th September 2012, 13:25
  3. Very poor performance 1.9 cdti
    By uk300bake in forum Engine & Drivetrain
    Last Post: 8th August 2012, 16:08
  4. No/poor Acceleration under 2.5k revs
    By Diesel Dan in forum Engine & Drivetrain
    Last Post: 16th December 2010, 23:44
  5. Limp mode, Emissions Light and poor performance
    By jonny_rubber in forum Vectra C / Signum Troubleshooting
    Last Post: 1st October 2009, 19:09
