Results 1 to 10 of 22
Thread: Vectra SRI headlamp/ sidelights
    Regular Member Philhammond2004's Avatar
    Feb 2011
    stafford
    Default Vectra SRI headlamp/ sidelights
    I recently bought a 57 plate Vectra SRi, I've upgraded my light bulbs (dipped beam's). There was a slight improvement but hardly any on the distance. I'm guessing its because of the design of the domed light which isn't completely clear which gives the poor lighting? Are there any different headlamp designs out there (uk) which have a better design?
    Also my sidebeam lights are pretty dim aswell (light yellow colour) Can these be upgraded to a brighter and better colour bulb which could improve on lighting?
    Any help or advise on any of the above would be greatful
    Liverpool
    Mtec 501's or LED's for your side lights work best, but the LED's will fool your cars computer that a bulb has gone so you need to get warning canceling ones or just get mtec's
    as for the headlight bulbs you can manually higher the beam distance to give you a better distance on the beam, but the best thing to do IMO is get some HID's, best mod i have ever done and will be the first on any cars in the future
    Feb 2011
    stafford
    Cheers for the reply mate, im guessing I can't get a new designed type of headlamp then?
    With Mtec 501's sidelights can I get these from halfords? Cheers
    Full Member gibbon7000's Avatar
    lincs
    Have you manually lifted the beam up using allen keys in the adjusters on the headlight unit. I had similar problems with mine. Did that and all solved. Theres a how 2 on it if you do a search
    My other car. 1972 1641cc slammed beetle. On the road finally!!
    Regular Member R-ford_Vec_C's Avatar
    St Helens
    I raised the level of my headlights, which made a vast improvement, then fitted HIDs, AMAZING by far the best £60 i've spent
    Feb 2011
    stafford
    where can i get HIDs Cheap? Cheapest ive seen so far online was about £180. Are the easy to fit or do I have to get a pro to fit them? Thanks for all the replies. All very helpfully. Not able to try any of them tho as im going on holiday 2morrow. Thanks again tho every1
    Regular Member Aikon58's Avatar
    Englandshire
    Vehicle : shatch- sports hatch
    Trim : cheap plastics
    Engine : metal
    Year : 1901
    Mileage : 999
    Not excactly this seller,but thses are the sort of prices to pay,mine works fine
    http://cgi.ebay.co.uk/Xenon-HID-KIT-...item4156b7e1f8
    Quote Originally Posted by Philhammond2004 View Post
    Crikey, where have you been looking? The car assessories equivalent of Harrods or M & S?
    Got mine from HIDS4US
    Other people will suggest HIDsDirect (who seem to have poor customer service and poor after sales service)
    Are the easy to fit
    Easy peezy. Either bumper off or removal of air filter box (I prefer the former) and then it's plug and play. There are a couple of how2's as well - in the how2 section of all places.
    Feb 2011
    stafford
    thanks again for the links and advice every1 3 more questions lol
    1st is whats the best colour temperature? 4300k, 5000k, 6000k, 8000k or 10000k? and are all of these road legal? Dont want 2b gettin pulled up with off road kit lol.
    3rd question is do i have 2tell my insurance company about this change? im guessin i do since its a modification
    All aftermarket HID kits sold have a disclaimer that they are for off road use only.
    However, they will pass an MOT providing the beam is set correctly. So make a note of your beam height before you start (chalk or pencil mark on the garage wall) then check again after fitting the HIDs.
    6000k is the best, IMHO. 4300k matches original factory fitted.
    Some people tell their insurer, some don't. I did and no extra premium was requested. All they did (Tesco) was to make a note on the policy.
  1. Vauxhall Vectra O/S AFL/Xenon headlamp
    By webtrawler in forum Electrical & ICE (including SatNav)
    Last Post: 6th October 2011, 02:27
  2. Vectra C sidelights
    By Nicolas in forum Electrical & ICE (including SatNav)
    Last Post: 23rd September 2010, 22:51
  3. Vectra C Headlamp bulb replacement
    By mss in forum Vectra C / Signum Car Chat
    Last Post: 18th January 2010, 12:41
