Hello there ppl,
I have a few issues....as follows=)
1.Spanner light comes on when car is first started,go's out soon after.
2.Smoke on start up when heat rods not engaged,(same quantity as a forest fire)
3.Small like sucking sound from nr rad when car is first turned off(very faint)
4.What gearbox code is it F?? (vec c 2.2dti ls 03 160,000m)
5.What and where are the vac pipes (pic if poss)
I read that the smoke could be leak off pipes so i replaced them aswel as the egr..or the vac pipes (is this true?)
Cheers in advance=)
