Results 1 to 10 of 18
Thread: injector cleaner
    Dec 2010
    south wales
    Default injector cleaner
    i"ve got a 3.0v6 siggy elite 06 with 70,000 it"s started to judder at about 1500revs so what injector cleaner is the best to try before i end up spending big bucks trying to sort it out which i ain got at the moment,any help would be greatfull.thanx.
    Jul 2006
    Northampton
    Trim : Sri
    Engine : 1.9 cdti 150
    Everybody uses millers but i dont. I use reddex, always have and swear by it. run your tank well into the red, whack in a small bottle (the 2 tank bottle) run it until the fuel light is flashing then fill up
    Regular Member Tam80's Avatar
    Aug 2010
    Dundee-Motherwell
    Quote Originally Posted by Danwells72 View Post
    The 2 Tank Bottle ?
    Size Is That ?
    Regular Member nikroc's Avatar
    Nov 2007
    DERBY
    13 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    Its a standard size..the bottle is actually marked to allow you to 'accuratley' measure when you have poured half the bottle into a full tank of fuel.
    Regular Member v6diesel's Avatar
    Southampton
    So are you saying that you add it to a near empty tank of fuel?
    Sep 2009
    Audley STAFFS
    I am a big fan of REDEX as well, when I first got this VEC it had a tick over problem and did not feel quite right,REDEX sorted this out, I use it quite regular, BUT I use it as directed on the bottle, one measure for 10 galls, I would be worried to use it as directed above.
    Aug 2010
    Dundee-Motherwell
    We Talking A 250ml Bottle ?
    Jul 2006
    Northampton
    Trim : Sri
    I was advised to do it this way by a mechanic as it will clean the injectors quicker due to the higher concentration. even with the low fuel level it is still quite diluted
    durham
    Trim : Leather
    I've heard that too, and don't think it'll do any damage at all. I use redex maybe 4 times a year on my v6 and think it can only help.
    Sep 2009
    Audley STAFFS
    go your own way mate, its just somthing I would not do, years ago yes,, but things move on, redex is highly concentrated now, one measure does 10 galls, so why use more?
  1. injector cleaner, fuel up grade to V power
    By mickg in forum Vectra C / Signum Car Chat
    Last Post: 25th May 2011, 22:43
  2. Injector cleaner
    By triple595 in forum Engine & Drivetrain
    Last Post: 30th April 2011, 15:32
  3. Redex or similar injector cleaner
    By RobW in forum Engine & Drivetrain
    Last Post: 14th January 2011, 15:43
  4. Injector cleaner
    By suggs1971 in forum Vectra C / Signum Car Chat
    Last Post: 14th March 2010, 11:15
  5. Best Injector Cleaner
    By s1nglef1sh in forum Engine & Drivetrain
    Last Post: 11th October 2008, 18:23
redex injector cleaner vectra c
