Thread: M32 gearbox can`t get gear selector back in gearbox HELP!
    Regular Member v33tra's Avatar
    ayrshire,scotland
    Default M32 gearbox can`t get gear selector back in gearbox HELP!
    Can`t get the gear selector into a M32 gearbox on a 1.9 cdti 120 and now can`t get it back out any advice gratefully recieved on how to do this pain of a job
    gearbox was removed to change DMF etc and to get at top gearbox bolt the selector needed taking off
    ayrshire,scotland
    daytime bump as i`m really stuck for idea`s on how to fix this ???
    ayrshire,scotland
    Help no longer required a bit of trial and error and i got it back into the gearbox although it is a horrible stinking job to refit and does involve taking the gearbox apart to allow access to the selector forks aswell as removing the gearbox from the car again however it is now fixed
    ayrshire,scotland
    For future reference incase anyone else comes across this problem here is an image of the gearbox split open to allow access to the selector forks which need realigning after removing the selector rod and housing
    after gear selector is refitted ( long tubular rod at bottom of picture under gears )
    gearbox reassembled & sealed back up with gasket sealer
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Well done on sorting it and some great pics
    VIP-Member GSiFan's Avatar
    Houghton Regis, Bedfordshire
    19 Post(s)
    Vehicle : Vectra GSi 3.2 V6
    Trim : GSi
    Engine : Z32SE
    Mileage : 216,400
    Useful thread. Thank you for sharing your experience with us.
    Paul
    2003 Vauxhall Vectra GSi 3.2 V6
    ayrshire,scotland
    This gearbox decided to chuck a bearing out the end of the casing last night so a new gearbox has been ordered from Vauxhall and will be fitted tommorow
    seems the M32 6 speed cdti gearbox is pants and prone to failure
    ayrshire,scotland
    Recieved my brand new gearbox from Vauxhall today just gotta get it fitted now
    Derby
    I am also in the middle of replacing the DMF/Clutch, and have so far unbolted the selector, but can't seem to wiggle it out of the box. I was going to wait until I had removed the top g/box mounting. Should I have disconnected the cables and left the selector in place? Do you always have to re-align the forks or was this just bad luck?
  1. Vectra C Auto Gearbox - Jumps While Going From 3rd to 2nd Gear
    By Tigra16V in forum Engine & Drivetrain
    Last Post: 13th September 2012, 15:33
  2. Gearbox Oil Change on GSi - How much to go back in?
    By v6vc in forum Engine & Drivetrain
    Last Post: 4th October 2009, 12:10
  3. Auto gearbox thumping in and out of 3rd gear
    By Paul H in forum Engine & Drivetrain
    Last Post: 14th January 2008, 23:31
m32 gear selector
m32 gearbox
how to remove m32 selecter
m32 gear selector removal
remove selector m32
vauxhall vectra 1.9 cdti gearbox selector removal
2005 zafira cdti gear selector removal
vectra C m32 gear linkage removal
vauxhall vectra gearbox m32 selector
m32 selector gear
