Thread: diesal fault code advice please
    Regular Member tj56's Avatar
    Apr 2008
    Tyne and Wear
    Default diesal fault code advice please
    hi guys. the missus has a vectra 2005 facelift 120 cdti and last week or so the fault light has been coming on then goin back off. eventually got around to plugging it into a code reader and got these 2 below.
    P0621 Generator Lamp "L" Control Circuit Malfunction
    P0380 Glow Plug/Heater Circuit "A" Malfunction
    In the morning the heater light comes on as normal before turning over and goes out, then when starting its a bit lumpy but then starts ok but been like this before fault light came on.
    its also a little juddery when in low rev range
    What do you reckon guys? take to vauxhall?
    thanks in advance for any advice
    Rob
    Apr 2008
    Tyne and Wear
    advice bump
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Most likely the glow plugs are at fault. Does it get better as the engine heats up?
    Gazza4
    Apr 2008
    Tyne and Wear
    Quote Originally Posted by Gazza4 View Post
    Gazza4
    hi Gazza, its the wifes car so she drives it 99% of the time. would a faulty glow plug (or more) give the lumpy start and judder when in lower rev range when engine cold and also put on the fault light?
    Also when the engine is warm would this turn out the fault light? this may explain the reason why it comes on then goes out.
    I do not know much about diesals, how hard a job is it to replace them and whereabouts would they be located? ive read that euro parts do set of 4 for about 40ish
    cheers for reply
    Apr 2008
    Tyne and Wear
    done a bit of searching and feel it should not be too difficult a job, sounds more fiddly than difficult as at rear of engine and EGR has to come off, which is fine as could probs do with a clean.
    Devon
    75 Post(s)
    Vehicle : insignia
    Trim : irmscher
    You might get more replys if it was posted in correct section
    Now moved
    Irmscher Insignia CDTI 130
    Apr 2008
    Tyne and Wear
    Quote Originally Posted by bigmac View Post
    Now moved
    thanks for that
    Apr 2008
    Tyne and Wear
    Default glow plug prices
    full set glow plugs @ Euro parts 56.52 (with VAT)
    AV Taylor (local factors) 26.92 (with VAT)
    Taylors are a lucas part and i am guessing the other is Bosch. any one used the lucas part and are they a decent alternative?
    cheers
  1. fault code help
    By Mads in forum Engine & Drivetrain
    Last Post: 11th August 2012, 22:43
  2. Fault code help!
    By joee91 in forum Electrical & ICE (including SatNav)
    Last Post: 13th July 2012, 00:52
  3. Fault Code help
    By MiniVauxhall in forum Engine & Drivetrain
    Last Post: 17th May 2012, 10:04
  4. Fault Code Advice.
    By Alank in forum Vectra C / Signum Troubleshooting
    Last Post: 13th September 2011, 17:00
  5. fault code 7e9 a/t
    By mackemade in forum Engine & Drivetrain
    Last Post: 3rd July 2011, 22:28
vauxhall fault code 7e9
