Thread: EGR Valve
    Jul 2006
    liverpool
    Default EGR Valve
    Hi guys
    My old man has not long bought an 06 3.0cdti signum.. The thing is its only got 6000 miles on it and as we were driving home in it today, the engine management light came on and it would rev to 1000rpm all on its own..
    We took it down to the stealers who diagnosed the EGR valve and are going to replace it under warranty for us.
    The thing is.. how can this have become faulty so soon??? and what can we do to prevent it happening again in the future please??
    Any advice gratefully received
    Darren
    Ashington, Northumberland
    Just one of those things mate. Just because things are new, doesn't mean they will last. You've just been unlucky and the chances are that when the new one is fitted, it'll never go wrong again. Anyway, good luck with it
    Regular Member IamtheStig's Avatar
    Nov 2005
    Somewhere in time
    On the older ecotec engines you could make up a blanking plate out of thin steel and use it like a gasket,as long as the egr valve stayed connected it never threw a spanner light and the engine was less hesitant and it also never effected the emissions enough to worry about
    I would doubt you could get away with it now though
    Like Gary said..just because it's new, doesn't mean it's going to be reliable and give long term service. All batches of parts run the risk of having a duff component in them.
    let them fit a new one and hopefully it will be fine for the rest of the cars life. there is nothing i know of in the way of a regular fault with the EGR valve.
    Jul 2006
    liverpool
    ok cheers for that guys...
    Will let u know how it pans out...
    Regular Member Maddog1974's Avatar
    Jul 2006
    Colchester
    They used to go wrong all the time when the cars were a few years old usually gummed up with soot etc. As said you were just unlucky i reckon!
    The main use for them was to re-burn the exhaust gasses to help reduce NOX emmisions. Not sure if that gas is part of the Mot these days or not?
    south wales
    I have had the same fault on my Vectra 3.0 cdti its only got 6k on the clock as well they reset the system but light came on again twice the other day,they said that if it happens again they would change the egr valve also the insp figure is reading 00 i rang the dealer and they say because the car is nearing a year old its due for service which i think is a bit soon as now its only on 7k..
    Jul 2006
    liverpool
    Quote Originally Posted by lopku001 View Post
    sounds to me like they are trying to delay repairing the fault until the car has reached beyond its 1 year life. That way it may be out of warranty so making you responsible for the bill. Labour charge on a 3.0cdti is huge!! Instead of just blagging you, they should just go ahead and change the egr valve.
  1. Brake servo Valve (one way valve)
  2. Replies: 6
    Last Post: 29th July 2012, 13:52
  3. Egr valve, swirl valve problems etc..
  4. EGR valve / Swirl valve
    By SwavGav85 in forum Engine & Drivetrain
    Last Post: 5th January 2009, 17:17
  5. EGR valve and Swirl Valve
    By TUX-VECTRA in forum Vectra C / Signum Troubleshooting
    Last Post: 6th July 2007, 00:43
