Results 1 to 10 of 13
Thread: EGR Valve query?
    Oct 2010
    South Yorkshire
    Default EGR Valve query?
    I am new to the forum so apologies if this thread is in the wrong forum?!
    I have an 06 1.9cdti sri 150 Vectra, I have been recently informed by a local dealer (& diagnosic) that the EGR valve needs replacing - at a cost of £90 for the valve and 2 hours labour @ £45 per hour.
    Anyone any help with getting it done cheaper? Also, I hear if you 'cap it off' the throttle response is better?
    PLEASE can someone help or elaborate on any of these points?
    Thanks a lot
    West Yorkshire
    More like 30 mins of your own time - wouldn't expect it would take 2 hours unless the garage are incompetent!
    Link to Autovax egr valve £84 plus shipping
    Link to the How2 change EGR valve
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    2 hrs - bull you can do it yourself in 45mins if you aint good enough with the spanners. All you need is a 13mm socket and 10mm spanner. Rediculous imo. The part price is fine though.
    Gazza4
    Oct 2010
    South Yorkshire
    Immense, cheers chaps. I'll have a go, it doesn't look too difficult (famous last words!!) What's this about 'capping it off' is this worth doing and is it difficult etc?
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    If you mean blanking - then I wouldn't waste the money buying a new one.
    This will put the EM light on though.
    Gazza4
    Regular Member DeanF's Avatar
    Nov 2007
    Staffordshire
    Or you could just service your Egr at very little or Nil Cost !!! Only your Time .....
    What do you have to lose ......
    http://www.vectra-c.com/forum/showth...ight=egr+valve
    Dean
    Mar 2007
    GB
    Vehicle : Insignia
    Trim : SRi Nav
    Engine : CDTI158
    Year : 2012
    Changed mine in literally under 10 minutes - no exaggeration. Easiest job in the world. Heard they charge this amount before, and it really is taking the **** to charge two hours labour for it! Unbelievable! Only thing though - do make sure you put a new gasket in and get it on tight there should be no problem. Check for leaks just in case - I guess they make a meal of checking for leaks in the garage and that's where there come up with 2 hours.
    Regular Member Tam80's Avatar
    Aug 2010
    Dundee-Motherwell
    Anyone Know If Theres A How To On The 1.8 EGR ?
    Sorry 4 Hi-Jack MVP
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Quote Originally Posted by DeanF View Post
    Dean
    Good how2 although when the valve is done it's on the road out. Some will claim it returns the car to normal but in time the poor sub 2000rpm performance comes back.
    Gazza4
    Oct 2010
    South Yorkshire
    Auto vax supply with x2 new gaskett's - at the risk of sounding stupid, how would I check for leaks?
  1. Brake servo Valve (one way valve)
  2. Replies: 6
    Last Post: 29th July 2012, 13:52
  3. Egr valve, swirl valve problems etc..
  4. ERG Valve and Booster Valve
    By st2malo in forum Engine & Drivetrain
    Last Post: 9th August 2009, 17:28
  5. EGR valve and Swirl Valve
    By TUX-VECTRA in forum Vectra C / Signum Troubleshooting
    Last Post: 6th July 2007, 00:43
