Results 1 to 10 of 21
Thread: Serious Gearbox problem or Replacement?
    Regular Member Elahi_786's Avatar
    Oct 2010
    Bedford
    Exclamation Serious Gearbox problem or Replacement?
    I had my car serviced today, one of the things to do on the list were to get the transmission oil flushed & get 2.4L of the stuff in there.
    Once the mechanic got the car on the ramp to do it, he noticed that theres is a grinding noise coming from the gearbox whilst obviously it was idling.
    For this reason he did not carry out the flush & replacement as he said it could cause further problems. He said it sounds like the bearings but he is not 100% sure I am going to see if MR Clutches can check the noise & see if they can come to a conclusion rather then strip it and then find the fault and end up having to purchase a second hand / reconditioned one.
    My car has been making a noise when accelerator has been down in gear, I have always thought it was the engine mounts or something small, do you the think the noise could have been the gear ?
    WHAT DO YOU THINK I SHOULD DO - SHOULD IT BE THAT THE GEAR IS MAKING THE NOISE? BUY A RECONDITIONED GEAR BOX / SECOND HAND / OR TAKE THE CHANCE GET THE GEARBOX STRIPPED AND SEE IF IT CAN BE RESOLVED STRIPPING INVOLVES SERIOUS CHARGES LOL.[
    Regular Member Jezzy's Avatar
    S.E
    Wait and see, and if it is indeed the gearbox then contact these guys for a price on a 2nd hand one:
    http://www.megavaux.co.uk/Engines.aspx
    Oct 2010
    Bedford
    Exclamation Ebay any good
    Lot of choice on ebay, can you recommend anyone so many to choose from what should I look out for?
    PRESTON
    would it per chance be the dmf rattling and not the gearbox bearings? gearbox's on Veccy and Signum are generally up to the job and fault free, more so than a dmf.
    Oct 2010
    Bedford
    Exclamation
    I dont think my vectra hatchback as A DMF.
    I think its on estate & signums something like that
    morecambe
    35 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    I think you will find they all have DMf apart from early1.8 and autos
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Quote Originally Posted by Elahi_786 View Post
    That's the DPF, your car has a DMF trust me. Has it been rattling? How is it when changing gear?
    Gazza4
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Quote Originally Posted by paulvectrac View Post
    They don't only diesels have them. 1.8, 1.8VVT, 2.2, 2.2Direct certainly don't have them.
    The 2.0T may due to torque but I doubt that.
    Gazza4
    Full Member Caveman_nige's Avatar
    Jun 2009
    South Coast
    Vehicle : Vectra and a Signum
    Engine : Z18XE,Z19DTH,Z20NET
    Quote Originally Posted by Gazza4 View Post
    Gazza4
    2.0T engines do have a DMF.. trust me on that one
    What engine does the Elahi_786 have? if the mechanic had checked/changed the oil he could have checked to see if their was any bits (filings) in it.. he has left you in limbo really, not very helpful.. you can pick up a secondhand f40 gearbox for about £250 delivered.. I have heard both good and bad things about MrClutch but I am not sure if they will offer any guarantee if your fitting a secondhand unit... thats your call...
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Quote Originally Posted by Caveman_nige View Post
    I did single it out. He has a 1.9. Goes without saying as soon as DMF is mentioned.
    Gazza4
  1. 2.2 Direct gearbox replacement
    By Gubmint Agent in forum Engine & Drivetrain
    Last Post: 1st March 2012, 13:34
  2. Replacement for the auto gearbox cooler
    By Lao in forum Vectra C / Signum Car Chat
    Last Post: 27th June 2011, 15:12
  3. 2004 1.8 gearbox oil replacement
    By rubachuk in forum Engine & Drivetrain
    Last Post: 25th January 2010, 15:51
  4. gearbox repair/replacement
    By jamesr in forum Engine & Drivetrain
    Last Post: 25th May 2008, 11:27
  5. Auto v Manual gearbox replacement cost
    By cabbage in forum Vectra C / Signum Car Chat
    Last Post: 30th June 2007, 23:30
