Results 1 to 10 of 11
Thread: lack of power
    Bristol
    Default lack of power
    Well after changing a dirty air filter and putting the swirl bar back on I now have a problem.sometimes when I go to pull away I have no revs ,with my foot to the floor the car gets to 2000 revs and the takes off. I have read on here that the manifold may need replacing . Before I changed the air filter and put the swirl bar back on I had no problems but then it was cold mornings, now its warm would this effect it.
    Bristol
    Come on guys,need a bit of help here.
    NI
    sounds like you've the same problem as me. I'll be keeping an eye on any responses.
    By having a look around the site it seems it's maybe swirl valves being stuck open, but that still means nought to me unfortunately!
    Newport (Shropshire)
    Vehicle : Ford Kuga
    Trim : Titanium
    Engine : 2.0dtci
    Mileage : 1200
    Is the swirl valve bar staying on, have you cleaned your egr valve?
    dunfermline
    check you egr and the ports that go to the inlet from the egr.
    clean both out and re try.
    i had this prob when engine was cold i removed and cleaned the throttle body, egr, and boost sensor on inlet all ok now.
    West Yorkshire
    Try Boost Sensor and EGR Valve clean - doesn't take too long, had similar issues and this cleared it.
    Regular Member neill's Avatar
    Nov 2009
    Warrington
    Vehicle : Vectra C estate
    Trim : SRI
    Mileage : 79000
    i had same problem on my 150, so remved the tb egr and boost cleaned them all and it worked a treat for a few weeks but hey ho its the same again. Think the inlet is probably gunked up aswell
    NI
    Is there a how to for the boost sensor and EGR valve clean on here?
    NI
    edit: just found the how2 for boost sensor, now for EGR valve..
    South Central England
    17 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    Get someone in the car to rev it from idel to red line (when it is pre warmed up to operating temp), while you look at the actuator bar. If it doesn't move, then your swirl valves may be jammed. At least three of them were stuck in one possition with the bar off, since you put it back, they my all be stuck in a different possition, that is resulting in losses of low down power. They should be closed low down to swirl the air in the cylinder and mix the fuel better. Might be worth unplugging the throttle body for one run to see if that is causing any issues; just plug it back in asap, as being unplugged causes heavy juder on shut down.
  1. 1.9 120 Lack of power.
    By carling in forum Engine & Drivetrain
    Last Post: 29th January 2013, 19:25
  2. lack of power
    By apache653 in forum Engine & Drivetrain
    Last Post: 6th February 2011, 20:18
  3. Lack of power...
    By lightfx in forum Engine & Drivetrain
    Last Post: 20th October 2010, 14:33
  4. Lack of Power
    By juggernaut in forum Engine & Drivetrain
    Last Post: 3rd April 2010, 16:20
  5. lack of power
    By astratovectra in forum Engine & Drivetrain
    Last Post: 20th February 2010, 19:56
