Results 1 to 3 of 3
Thread: starting problem
    Regular Member steve19cdti's Avatar
    Nov 2010
    s.wales.bridgend
    Default starting problem
    hi all got problem starting car in turn the key engine turns over as normall but got a load rattling only on start up its 54plate 1.9cdti 120 done 98k
    plus ive got a judder three may be four times a day hot or cold mostly low revs eny body had same problems .
    Nov 2010
    s.wales.bridgend
    not bd 18 views no one comments? so i gues no ones come across these foults then
    PRESTON
    Is the rattling just while the starter is turning? if so it might be that on it's way out or if it's from the engine, maybe it's the cam rattling before the oil gets there, either meaning the clearances need adjusting or the oil pump failing. When was the last oil and filter change? might be something simple as that. Trouble is, these engines are complex and theres a whole lot of things it might be. perhaps if you could post a short youtube vid of the noise, more members would be inclined to comment.
  1. starting problem
    By tiimi in forum Vectra C / Signum Troubleshooting
    Last Post: 25th October 2012, 20:32
  2. Starting problem
    By trace in forum Insignia car chat
    Last Post: 7th April 2010, 07:18
  3. Problem...? Vectra SXI...problem with starting after filling with fuel?
  4. Starting problem
    By DerekFB in forum Engine & Drivetrain
    Last Post: 19th August 2008, 19:54
  5. starting problem
    By chunkster in forum Vectra C / Signum Car Chat
    Last Post: 16th March 2008, 13:09
