Hi,just would like to know because I'm not too sure if I do the ECU RESET on the engine management would I have to re-program the remote keys or will it do it automatically?
Dont do an ECU reset, I believe it will then require a dealer type reprogram.
Just clear fault codes.
I'm sure someone more knowledgable will confirm this.
DO NOT RESET THE ECU!!!!!
It will mean you will have to reprogramme everything!!
DONT DO IT!!!!
I wont now...cheers guys
just did that today....shame really (curiosity that leads you to trouble) Took me another hour to start the car again but did that with op-com only.should I check anything more than immobiliser and ecu program? -cos that's what I did
For support on ECU programming try looking at Diagnostics.co.uk, or Ilexa.co.uk
The first is operated by a lad called Richard Peck or "Pecky".
He uses Tech 2 (original official) device..
Ilexa can give advice and information on Op-Com programming.
I know other forums, but these are not to be discussed on this forum due to the potential legalities.
Returning to the original question..
Then no DO NOT RESET the main ECU.... and definately do not reset more than one module at a time !!!
It really is a matter of reprogramming the world and it's wife..!!
If it ain't broke - don't fix it !!
By all means clear your fault log, but do not reset anything..
