Thread: HID & lights questions
    Regular Member jatint's Avatar
    Kilmarnock
    Default HID & lights questions
    I have searched for the answer and cant find it.
    I have vectra 1.9cdti facelift 2006 150 sri model
    I bought 6000k HID's specially suitable for canbus systems
    Also LED's sidelights suitable for canbus
    My driver side is much duller than my apssenger side & i need to flick lights on & off about 5+ times to get the drivers side to come on.
    And my side lights flicker
    I have decided to cut my losses and as i found a link to HID's direct with ones made for the vectra i have bought
    new 6000k HID's and sidelights which state there is no warnign lights,
    Will the sidelights still flicker?
    What could be cause to my driver side taking 5+ times to come on and why is it duller even after they heat up?
    Sodding Typical on Sea
    Sounds like (if I read this right?) the side lights are the issue not the HID's if so then it is probably a failing LED bulb as the new crop of SMT ultra-bright LEDS can die easily unlike the older ones that last forever and a day.
    If yo can see if you can get it swapped where you bought it.
    If however it is the headlight that takes so long to illuminate try swapping ballasts over to exclude them from your fault finding as it sounds like an earthing issue somewhere.
    Finally please be gentle with the on/off of your HID's as that is the main reason bulbs fail if they are on-off frequently. Far better to switch them on and keep them on for a decent spell.
    Kilmarnock
    Well the driver side just wont even come on it flickers and goes off till about 5 times then ti'll stay on
    has anyone else had this?
    I have a new kit anyway, so will see if i have same problems with this kit
    Sep 2010
    mine were great for 7 weeks and one went out completely, no flickering, worked a few hours later and stopped again. Replaced the ballast with a new one and now fine
    Administrator Big-Pete's Avatar
    May 2007
    Home or in the Gym
    95 Post(s)
    Vehicle : Audi Q7
    Trim : S-Line Plus 245
    Engine : 3.0 TDV6
    Mileage : 3023
    Moved to a relevant section.
    General Chat Any non-car related chat, but still of some useful relevance to people i.e. not idle chat, comedy or spam threads - use the relevant sections for those.
    Kilmarnock
    I'll see what my new kit is like when i have time to take bumper off again,
  1. Sidelights, Number Plate Lights, and Interior Lights
    By tony-1977 in forum Vectra C / Signum Car Chat
    Last Post: 2nd January 2012, 07:34
  2. Replies: 2
    Last Post: 31st March 2010, 13:30
  3. Philips bluevision h7 head lights & side lights brand new
    By davidlewis24 in forum Parts for sale
    Last Post: 19th March 2009, 22:42
  4. Dark lights and Rear Lexus lights finally fitted
    By Leviathan in forum Styling
    Last Post: 29th February 2008, 22:35
