Thread: 2.2 direct.possible leaking gearbox.
    Jun 2009
    Middlesex
    Default 2.2 direct.possible leaking gearbox.
    Has anyone with a 2.2 direct come across a leaking gearbox.Have not had chance to have a good look but i think it is a possible leak.Firstly how do i check gearbox oil level.Secondly any ideas where the leak could be from.
    Thanks Dobs.
    swansea
    I have oil on the base of my gearbox, not enough to cause a drip tho'. What year is your car, mines Oct 2005.
    Jul 2009
    barnsley,yorkshire,GB
    Engine : 20 Dti
    level plug is half way up gearbox about a couple of inches in,if it needs topping up removed reversing light switch to add oil.
    check oil seal where drive shaft exits gearbox
    Jun 2009
    Middlesex
    My 2.2 direct is an April 04.Several drops of oil on bottom of engine sump.I have checked and leak is not coming from engine sump plug.Could this be from gearbox?
    What spec if oil do i need for the gearbox?
    Thanks Dobs
  1. 2.2 Direct gearbox replacement
    By Gubmint Agent in forum Engine & Drivetrain
    Last Post: 1st March 2012, 13:34
  2. gearbox fluid leaking ?
    By pro auto valet in forum Engine & Drivetrain
    Last Post: 25th October 2010, 19:59
  3. vectra c 2.2 direct auto gearbox oil help
    By davidlewis24 in forum Engine & Drivetrain
    Last Post: 5th May 2010, 17:04
  4. 2.2 Direct Gearbox
    By Sean-2.2Direct in forum Engine & Drivetrain
    Last Post: 5th July 2009, 22:36
  5. would the 6 spd gearbox fit my 2.2 direct
    By pogo in forum Engine & Drivetrain
    Last Post: 4th September 2008, 14:33
vectra c driveshaft oil seal replacement www.vectra-c.com
