Results 1 to 10 of 14
Thread: vec 1.9 air box mod help
    Barnsley
    Default vec 1.9 air box mod help
    laning on doing it t moz and so far as far as i understand i need open it up remove the piece from bottom then cut the tube off the lid n the inside?
    is this the mst up to dat way to do this or am i missing something ?
    anything else i should do well at it ?
    any help advise appreciated
    Sep 2009
    Glasgow
    no just remove the clip in bit at bottom..
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Don't touch the tube on the inside of the lid at all let alone remove it. Doing this will reduce power if anything as the airflow will not be smooth especially when it passes through the MAF. On top of that it will increase fuel consumption. Just remove the plastic trumpet like piece from the bottom of the aibox as directed in the how2.
    Gazza4
    Barnsley
    looked in the how 2 and it said use saw to remve the tube as with it in it only uses half teh air box
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Quote Originally Posted by kirky2k4 View Post
    Doesn't say anything about the tube on the lid. It is funnel shaped so that air is passed though the MAF and into the engine as smooth as possible.
    Gazza4
    Barnsley
    Quote Originally Posted by Gazza4 View Post
    Gazza4
    you got a link to the how2 must be old how 2 im reading threw
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Only talks about the bottom plastic bit not the one on the lid of the airbox.
    http://www.vectra-c.com/forum/showthread.php?t=15122
    Gazza4
    Barnsley
    cheers mate what difference does it make if any?
    also what filters do every 1 recomend k&n ?
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Someone removed it apparently and the tube on the lid, and it played havoc with performance.
    The K&N has a shallower depth and relieves the pressure drop in the air box alongside the removal of the plastic bit. Doing these mods doesn't actually allow more air into the engine. It reduces the pressure needed to draw in the same quanitity of air, hence some ponies are sent to the flywheel and subsequently to the road wheels to pull the car better.
    Gazza4
    Barnsley
    great info cheers.
