Thread: remote central locking
    cardiff
    Default remote central locking
    Can any body help ? last night i locked my car as usual then this morning ive gone to open it and none of the buttons on the fob works . Ive replaced the battery and tried to resync the fob with no joy ! any answers would be greatly appreciated . also ive noticed the there is no chip in the corner of the key , i dont know if this is right but on my old vectra b key there was a chip in there????
    11 Post(s)
    Chip is on the board somewhere. Not immediately visible.
    How did you try resync'ing it? Two different ways, depending on age of car.
    cardiff
    Default central locking ???
    Hi mate i didnt know there was to ways of syncing the remote . the way i was told was to get in the car turn the ignition on so the dash board lights are illuminated and then press the lock button on the fob within 10 seconds then the doors are supposed to lock then unlock ?? mine never did that !!
    11 Post(s)
    Quote Originally Posted by mifandmif View Post
    That's one way.
    The other way mentioned in the handbook is:-
    "unlock door with key in lock. Inserting the key into the lock synchronises the radio remote" I'm pretty certain you also have to put the key in the ignition - which you would have to do anyway to silence the alarm.
    If however you can silence the alarm with the remote fob, then the problem is with the central locking and not the fob. Have you checked the C/L fuse?
    I take it that your key isn't a flip key? What can happen with the older type keys is a dry joint can occur on one of the battery contacts inside the fob. Now you can either attempt to resolder the joint, or place a thin piece of card on top of the battery and close up the fob, which then pushes the battery down harder on the contact.
    SCOTLAND
    I have a strange prob with mine, i have one key which will lock the car but wont open and the 2nd key is the opposite, opens every time but struggles to lock seems to be a prob with the little rubber buttons. Think i may need to order a new key but will try a bit card first
  1. Remote Central Locking
    By BaileySRI in forum Electrical & ICE (including SatNav)
    Last Post: 18th April 2012, 13:10
  2. Remote/central locking issue with driver door
    By Archaon in forum Electrical & ICE (including SatNav)
    Last Post: 3rd December 2010, 08:49
  3. help remote locking
    By swvectra in forum Electrical & ICE (including SatNav)
    Last Post: 9th June 2010, 19:45
  4. remote central locking doesnt work!!!!!!
    By Chippie19 in forum Vectra C / Signum Troubleshooting
    Last Post: 9th August 2009, 08:32
  5. Remote Central Locking - press open just once for all doors?
    By petesaysblimey in forum Electrical & ICE (including SatNav)
    Last Post: 21st April 2009, 08:54
