Thread: Sort of Productive weekend
    Regular Member RobW's Avatar
    Tain - Easter Ross
    Default Sort of Productive weekend
    Was changing my broken spring, fitting new front pads and changing the thermostat.
    Springs went OK after a while (APEX, will get pics when clean and daylight!) but none were broken so WTF is the noise!!??
    Brake pads came off OK, were well worn but after about 84k I'd guess they would be! Disaster strikes though - threaded a slider bolt AND knocked the wire on the passenger side for the ABS and TC.
    Never got to the thermostat!
    So, asked a garage local to my work yesterday to fix the threaded slider (was just in and no more but was barely using the brakes) but he didn't get time, nor today but said I could use all his facilities and he would guide me where needed! Bonus! Got it sorted, just needed to tap (or is it die?) the bolt once and it was sorted, also got the new discs on.
    Moral to the story - befriend a local back street garage and get use of a proper garage instead of a driveway, trolley jack and axel stands!
    New hub ordered - need the ABS light off for the MOT at the end of the month.
    And it turns out the 'boing' noise is the strut top bearing Had a quick look and they are not cheap!
    Regular Member 0uT1aW's Avatar
    Aug 2010
    York
    Sounds like a nightmare, strut top bearing is around £15 mate, just been quoted from autovaux
    Tain - Easter Ross
    Ah. lol - I did a quick ebay search and they were £59 or so but that was the bearing and the mount!
    Autovaux it is then! Is that an MOT fail part?
    Regular Member Mopar Man's Avatar
    herts
    Quote Originally Posted by RobW View Post
    If up and down movement is more than 7mm i think.
    Aug 2010
    York
    This is what I got from autovaux mate so you have P/N if needed
    According to GM parts catalogue, part number requested is correct, they are not currently listed on the website, price is £15.05 each inc vat
    P/N 13270705
  1. Had a productive weekend
    By Jamston39 in forum Vectra C / Signum Car Chat
    Last Post: 18th February 2013, 21:19
  2. Productive day, sort off.
    By Das in forum Vectra C / Signum Car Chat
    Last Post: 30th May 2011, 21:23
  3. Quite a productive weekend
    By RobW in forum Vectra C / Signum Car Chat
    Last Post: 21st February 2010, 15:25
  4. Productive day...
    By danBoy in forum Vectra C / Signum Car Chat
    Last Post: 20th January 2008, 21:42
