Results 1 to 2 of 2
Thread: cdti fuel pump sprocket
    Feb 2011
    bedford
    Angry cdti fuel pump sprocket
    hi there all, brill website definitely going to use this more often
    just wondering if anybody can help me. i have a vectra 1.9 cdti 150, i'm replacing the inlet manifold which i'm sure you've all heard about once or twice before. everything is removed apart from the fuel pump sprocket. for the life of me i can't get it undone i've done the normal trick of two bolts through the pulley which when i come to undo they bend like bananas i've made a 6mm plated fork tool with heavy duty bolts and still i'm not getting anywhere. i am doing it anti clockwise before anybody thinks the obvious.
    any advice please
    thanks
    Feb 2011
    bedford
    update
    nut is now off, had to grind it off. think somebody over tightened it. inlet manifold now off. easy enough job. thanks
  1. Vectra cdti 16v fuel pump question
    By paulcdti150 in forum Engine & Drivetrain
    Last Post: 19th September 2011, 17:12
  2. Crankshaft Sprocket Bolt 1.9 cdti signum
    By alkez100 in forum Engine & Drivetrain
    Last Post: 21st June 2009, 15:36
  3. CDTI Fuel pump
    By kevster in forum Vectra C / Signum Car Chat
    Last Post: 20th October 2008, 13:27
  4. 1.9 CDTI 150 Fuel pump failure...help!
    By sri150 in forum Engine & Drivetrain
    Last Post: 13th November 2007, 15:19
  5. CDTI Fuel Pump problem
    By bennyk in forum Engine & Drivetrain
    Last Post: 13th July 2007, 16:59
vectra cdti fuel pump sprocket removal
